I find the thin blade stock and thin grind to out cut any of the other style knives I own, even when the other knives are ''sharper''. This is particularly true with a properly made custom knife.
The real difference is made in the thickness behind the edge - a properly ground slip joint should be almost as thin as a chefs knife behind the edge. For example, my sebenza is made from 1/8'' thick steel or .125 inches , my slip joint is ground from 3/32'' stock .093 inches. Behind the edge my slip joint is ~ .005 inches, my sebenza is closer to .020+ behind the edge. So even though my sebenza will currently shave hair and my slip joint wont, I find the slip joint to move through material better.
that being said, the thickness on a SAK tinker is .07'' which is very thin and I can not think of one modern folder that uses such thin stock. My delica comes close at .09'' but again, the thickness behind the edge makes the SAK a better slicer.
Yep. I had to re-learn how to make fuzz sticks with my SAK because it had a tendency to slice through the wood and I just ended up with a pile of shavings instead of nicely curled fuzz sticks. This, the fact that it carries better in the pocket, the PC issue and the fact that it's a simpler design with less parts to break make it a winner for me.
I carry them if I want to, older steel, maybe 1095, not run hard, dull in a hurry. Mostly for fun, if I want to get work done I grab something s30v or better.
Opinel with M4 or k390 would kick everything out of my pocket.
I don't see why there aren't more thin style blades available because they cut much better than pocket wedges (ZT, Benchmade Adamas/755 etc.)
Yeah, I wonder why they don't make more traditionals in super-steels?
For those who carry a slip joint as a primary blade: Any specific reason for doing so, other than aesthetics or nostalgia? Just curious.
