- May 30, 2006
I'm moving into my new shop, and have found out that my 1.5h, 110v, 15A belt grinder SOMETIMES trips the 20A breaker.
I have a pulley system on the motor, and the problem arises when the pulley is set for the highest belt speed - it runs fine otherwise.
Shop wiring is all 12ga - it's run from the breaker box in the garage, underground to the shop out back, and there are 4 identical circuits. The grinder trips all of them on high speed.
At my previous shop, this wasn't an issue with 12ga wiring and a 20A breaker (although the florescent light I had plugged into the same circuit would dim until the grinder got up to speed).
There's no other equipment running on the circuit with the grinder when it trips.
Can anyone tell me if there is a (safe) quick fix for this? I can run a 220V circuit and switch the motor, but it would not be fun. Is there an easier way?
