So I've been scooping around looking at sharpening systems and I found out this thing called Arkansas stone (yes, I'm green as a lime) .
After doing a little research I found out that .. hey!
They also use the same grit system. Behind all the fancy names , Soft Arkansas , Hard Arkansas and Hard Translucent .
I'll think they should be pretty similar in performance with other stones of the same grit right?
For example , a 1000 grit Arkansas should do the job just as well as a 1000 grit India stone right ? And a 1000 grit India stone will sharpen just as well as a 1000 grit diamond... right?? I mean.. they are the same coarseness after all...
Or is it?
I've found out that on the Lansky site , the Arkansas systems sells a lot higher per stone than the man-made Alumina-oxide stuff...
So there has to be a reason .... besides from the stone maintenance reason
[video=youtube;2v80nevB8ho]http://www.youtube.com/watch?v=2v80nevB8ho[/video]
So... what else affects how polished the edge can be beside from grit?
Or is it?
