A Scandi ( short for Scandinavian grind) is a flat grind to the edge. It normally goes only partway up the bevel, thus determining the edge angle. It is shaped on a flat stone or flat platen on the grinder.
A sabre ( AKA saber, named after its use on single edged swords) grind is like a Scandi, but has a small secondary bevel at the edge.
A convex is a curved surface grind to the edge. It can go all the way to the spine or only part way as in a Scandi/sabre. Some convex grinds have a very small secondary at the edge. A convex grind is shaped by slightly rotating the blade as it is worked on a stone ( as in togi) or on a slack belt or rotary platen. In Japanese blades the bevel is often called an Appleseed grind, and the overall blade grind is called shinogi tsukuri.
You can't have a combination of these. It is either a Scandi, a Sabre, or a convex.
