- Oct 14, 1998
First off let me say that the Talon in 154CM is one darn fine knife (even whether or not you take into account the great bargain price)! The blade and handle shapes make this one of the best general utility knives (both production and custom) I have had the pleasure of owning.
However, I have one small issue regarding the knife I have yet to fix. The knife (specifically the area between the scales and the tang) has a habit of leaving oil/grease stains on anything it touches. My hand starts to get quite greasy and slick after a bit of usage, and though I cleaned off the knife several times and wiped up the offending area, the oil keeps seeping out. I also removed the scales and tried washing the tang and the scales and replacing the default oil with something a little more viscous and in less quantity, and though it helped a little, my hands still get a bit more greasy than I would like (no it's not my hand that is causing the problem, I checked on other knives already
Maybe the area I live in has had a lower atmospheric pressure allowing the oil to more likely seep through. Maybe I tightened the screws too much when re-attaching the scales. Maybe I need to just remove all the oil in betwteen the scales all-together (would rust between the tang/scales be an issue?).
Can anyone make some recommendations on how I can alleviate this issue?
Thanks in advance.
Felix
[This message has been edited by Felix (edited 05-10-2001).]
Thanks in advance.
Felix
