- Feb 23, 2009
I drill my folder holes by hand with a flexible shaft machine.
How's that working for ya ?
Cliff
Drilling is a roughing operation to remove material from a hole, but not to make an accurate hole. Not many people are following a drilled hole with a single point bore these days, but that will get it round and square prior to reaming.
For most needs, an accurate hole is spotted, drilled and reamed. You can use a "preream" endmill to chase a drilled hole prior to reaming to get it square and in position, similar to boring.
If you're just drilling and not reaming, your hole is not round or dimensionally accurate and, IMO, isn't good for much.
...my .02...
but it's one of those cases where, depending on what kind of folders you make, and how, this simply may not be necessary or worth the effort.
Many of the best old makers I've spoken or spent time with, don't ream any of the holes. *shrug*
That said, I've seen a lot of wobbly old slip joints. Reaming is such a simple way to make a round accurate diameter that will have less play and age better than a rough drilled hole, I can't see skipping it on something like a pivot.
