I have gotten some titanium bar stock from a friend. I have several pieces that are .5" x 7" x 16". I would like to forge these into some unique blades, but have never worked with ti. I have searched, and found this:
And I've been told to keep baking soda around to dose it if it catches fire. Is there anything else I need to know?
Thanks guys
To forge the blades I took them to 1000C (yellow) and hammered til they were red (about 900-870C) and then I took the Ti piece to the oven again til it was yellow and started all over again til I got the desired shape.
This forging process took me about 3 times the time it takes me to forge 5160 as the Ti gets cold sooner than the steel.
The blades have a 47RC hardness, and I didn't heat treat it after forging, as the Ti got hardened in the process.
I find the behavior of this knives edge wise to a knife made out of 1070 with a hardness of 56RC. After I sharpen them, they get razor sharp and can shave arm hairs. After some use (again, picture a 1070-56RC knife here) they stop shaving hair, and might seem dull, but they keep cutting meat and tomatoes and potatoes with ease.
From what I've read, this is because of the micro structure of the Ti, that makes the edge to resemble a micro saw, so if you move the edge agains the food, it will cut like hell still.
Also, I've read that if you reheat Ti several times, it becomes brittle... This is NOT what I found here, as the blades are almost as maleable and flexible as steel ones.
I find this material to be exceptional for kitchen use, as they are light, so after prolongued use you don't get as tired, they don't give any foreign taste to the cutted food like some carbon steels might, and because with a sharpening rod you can get it popping sharp again in some seconds, so if you remember to do that just before each use, you'll have a REALLY light and super sharpened kitchen knife at your disposal.
Regards,
Ariel
Thanks guys
