I'm trying to improve my freehanding technique on benchstones and would appreciate some tips.
On alternating sides:
Is it a bad idea to get your angle and grip solid, and then do say 5 or 10 strokes on one side, before you flip the blade over and do the same amount on the other side? I find it VERY inefficient to do a single stroke, then have to flip the blade over, get a new grip, sort of re-estimate the angle, and stroke the other side every single time. It seems more efficient to make 5 or 10 passes with the same grip. But I don't know if this is a bad idea and causes things to get unbalanced on your edge.
On directions:
Do you always sharpen by doing a push-stroke in a direction pointing away from yourself? Meaning of course, that you have to alternate left-hand/right-hand each time when you flip the blade over? Or, do you do an AWAY stroke, and then flip the blade over, and do a RETURN stroke (bringing it back toward yourself), so you can keep the blade in the same hand going both ways?
I've seen people use both of the above approaches. Curious if one works better than the other, consistently.
On getting the tip sharp:
What do you do to get and keep your tip super sharp (and avoid rounding/blunting it)?
On directions:
