RAGS said:...but I would need to take it apart in order to do it.Has anyone here taken a 110 apart...
Joe Houser said:Assuming the knife is not super old, you could probably to it if you have replacement parts. If you want the knife in half, you will have to remove two bolster and one blade rivet. This is kinda tricky because you can't always see them.![]()
nagamitsu said:Are the bolster rivets counter sunked ?
What are the sizes of the bolster pins, rocker pin and scale rivets ?
chickentrax said:It's easy to find the bolster rivets if you clean it real good [I wiped with lacquer thinner] then let it oxidize for a few days (just let it sit out without cleaning)...![]()
nagamitsu said:Thankyou for the measurements chickentrax.
I have no trouble finding the pins at all. My hands, coupled with the tropical environment are that corrosive, the brass greens a few hours after polishing & handling.
