- Sep 12, 2002
I have decided to make my own grinder. Is there any reason that the tracking wheel must be four inches rather than two inches in diameter?
Thanks in advance!
Ron
Thanks in advance!
Ron
Thanks in advance!
Ron
The larger the wheel, the less severely the belt has to bend around them.
It's better on the belt
Bearings
A two inch wheel will be forced to run twice as fast as a four inch wheel.
That would be hard on the bearings and generate much more heat
The smaller wheel has less mass to absorb the heat.
Bearing failure
Only if your idler wheels are 2" in diameter. If your idler is 4", it only makes 1/2 a turn for every one complete turn of your 2" wheels.The 2" wheels on the platens of my machines run just as fast as the idler wheel?
+1 on vwjackstraw.Check out ebay seller vwjackstraw. you can get a full set of wheels for $150 bucks or so that are very well made, and well worth the investment. In my opinion, these are made as well, if not better than any other wheels on the market, and quite a bit cheaper than a lot of the competition.
I got ya, that makes sense. I hope I get that kind of life out of my bearings. I'm sure you're right about the 1" and smaller wheels, it's not hard to get the bearings in those going fast enough to create some serious heat.I understand that, What I meant is the 2" wheel on my Platen of my Hardcore Products are now about 18 years old and so is the idler which is 8" & none of them have needed replacing. I think when you get to 1" or less wheels there may be a shorter life span on the bearings.
