- Sep 13, 2004
Email me or call. I will help you any way I can.
godogs57 said:Mike,
My main problem is the initial cut after drilling the holes. Example: I am cutting a slot for a 1/8" thick blade...well, of course, you have to use a bit smaller than 1/8" for your starter holes...just about every file I have, or can buy, is not thin enough to get started through the holes...excepting a "points" file from the auto store..and it is murder to hang on to while trying to get it started through the hole...
My slotting files that I use after the hole is enlarged are flattened on the side so it wont lengthen the hole...brilliant minds think alike I see.
Be good.
Sando said:Here's a slotting idea for you no-mill guys (like me). Just stuff I learned from the guys here.
Drill 2 small holes at each end of the slot.
From the back side drill some holes where the slot is going but larger than the slot using an end mill. And NOT all the way thru. Leave as much thickness from the front as you think you need to hold the guard in place. (I leave a good 1/8"). Now you only have 1/8" of material to slot.
Using a dremel tool and a cut off wheel, make the slot but a bit narrow.
Now file to size.
Leave it tight. Clamp the ricasso in a vice. Slip a pipe over the tang and pound guard in place.
The real kicker is using that cutoff wheel to make the first slot. Really helps and you don't have to start with those tiny files.
Steve
Terry_Dodson said:so is it ok to use end mills in your drill press if you are just cutting straight down? If so and the end mills dont flex can you just overlap your straight down drillings to make a slot? I know i cant overlap holes using a regular drill bit because they flex and glance off.
ddavelarsen said:Michael I am very interested in learning about your CNC setup. I'm going on vacation in a couple days so will be out of contact for a while but when I get back I'd like to strike up a conversation with you on this if you're up for it. CNC milled slots sounds like just the ticket! And I have a junk computer I can designate for the tool. (It's a PC; I use a Mac for real life.)
