This is mainly for Chris, since he made the decision to do this (I'm assuming), but the opinion of others is always welcome.
I'm wondering about the convex edge on the Sebenza, in combination with the hollow grind that's used. Is it necessary to the overall strength of the blade?
I ask because I don't have the equipment to grind convex edges (such as a thick strop, or wheel). I only have a Sharpmaker, which after enough time is going to turn that beautiful convex edge into a plain double-bevel edge. (BTW- Check out the Sebenza's blade grind under a microscope if you can. It's very well done).
Would a double-bevel edge significantly weaken the blade? Is the BG42 strong enough to support a "straight" edge, rather than a convex one?
Now I know I can return it for sharpening, but I hate doing that unless necessary. Self-sufficiency has always been attractive to me, and if it's a matter of having the right equipment, that's what I'll do.
Thanks for your attention on this matter, Chris. You've yet another Sebenza lover in the ranks.
