The Bark River forum on "knifeforums" is even talking about you now.
That would be the differnence between us, I will talk about the steel, I'll also tell you the details to support the arguements I have made, I'll provide you with the materials references from multiple sources as well as the knives I have used.
... in my tests it outperforms BRKT's A2 for edge retention. In fact the simple 1095 tool steel that Eriksson uses in their Mora knives costing less than $10 has better edge retention.
That isn't surprising, I would expect a lot of retained austenite in underhardened A2. In fine edges that falls apart, you can see this in Beach's and Elliott's A2 planer blade tests. However as I have said many times, don't use results like these to judge the steel. Look at the materials data, see where it maximizes performance, try a blade there and if it still has low performance then contact the manufactuer of the steel, confirm it, and then write it off - assuming you somehow have a way to explain the contrast between the materials data and the expected performance.
We have tried them harder and when I can drop a 60-61 A-2 Blade on the floor and have it Break in half--I don't call that Shining. I call that too hard.
I call shenannigans. This is completely absurd, first off the extreme minima that some steels have comes from tempers which lie along carbide precipitation ranges. Ironically enough, this happens to a lot of steels when they are tempered to draw back the hardness, yes, they get more brittle as they also get softer and weaker (and lose wear/corrosion resistance - like I said, it is a bad thing to do). A2 will in fact do that, but not nearly so dramatic.
A2 simply doesn't have the carbide volume to induce such a change. You will see such large responces in M2 and similar steels where the toughness can drop to a small fraction of the minimum. However none of the materials data for A2, torsional or charpy/izod show such behavior, because as noted, the carbide precipitation problem isn't that much of an issue. Makers also run at A2 at that hardness and their blades do not have that performance.
Our Heat Treat is not like others and we do a Triple Temper --Twice in the Cycle- on Every Blade. All 6 tempers are at Different Temperatures.
Fowler actually does the entire heat treatment three times, read Cashen's comments on if that is actually productive and check the materials data he provides to find some arguement for that level of complexity. Any arguement for exactly what each part in this complex cycle is doing which is supported by actual published materials science? Nope.
However, they are prone to, let's say, a certain Jekyll and Hyde quality when someone has the temerity to suggest that something BRK&T has produced might possibly be made even better if done slightly differently.
That isn't restricted to BRK&T, it happens whenever any maker runs a forum they moderate and they don't actively prevent such behavior. All you are seeing is the cult mentality that forms in any club house. But if you really feel those are the types of places which are ideal for discriminating information, well, I have a few people in real estate who would be very interested in talking to you.
-Cliff
