- Jun 20, 2007
I am going to try my hand at a few folders, and a question has arose in my mind about clearance on the pivot point. It runs in my foggy memory that I remember someone in a tutorial talking of using a shim/washer on the balde, so here is the questions that pop into mind.
When building a folder do you use a washer at the pivot point on each side of the blade or not?
If you do what are you buying and where?
If not what is the proper procedure to allow for clearance/ ease of blade swing?
In the past I have used Pewter for some of my bolsters. It tends to be a soft material to work with and easy to cast.
Is there some way to harden the mix.
How about adding Silver, would that give a better shine as well as hardening the final product?
Does Silver melt anywhere close to the same temp as Pewter?
What is the common material and thickness of the material used as the shell/spacer between blade and actual handle material?
Are you just buying sheet goods, and where are you ordering it from?
I guess that's enough questions for one thread. Now if I just get answers to all of them I will feel fortunate!
