Thermal Treatments
Critical Temperature: 1530F(830C).
Forging: 2075F(1135C) Do not forge below 1700F(925C). Slow cool after forging.
Annealing: 1600F(870C), hold 2 hours, slow cool 25F(15C)/ hr max. to 1000F(535C), then air or furnace cool. Hardness BHN 217/255. Stress Relieving: 1100-1300F(595-740C), hold 2 hrs. and air or furnace cool.
Straightening: Best done warm 400-800F(205-425C.)
Hardening: (Salt Baths or Vacuum Furnace preferred.)
Preheat: 1500-1550F(815-845C), equalize.
High Heat: 2100-2225F(1150-1220C), soak 2 to 5 minutes. For vacuum hardening, use the high side of the high heat range and soak times.
Quench: Salt or oil to 1000-1100F(540-595C), equalize, then air cool to hand warm, 150F(65C). Temper immediately. The vacuum quench rate to below 1000F(540C) is critical to achieve comparable results.
Temper: Tempering at 1000F(540C) or higher 2 times for at least 2 hours at temperature is recommended. Air cool to room temperature between tempers.
Hardening Data
Oil quenched.
Tempering
Hardness HRC
Temperature
2100F
(1150C)
2150F
(1175C)
2250F
(1230C)
°F
°C
975 524 64 65 66
1000 540 64 65.2 66.8
OPTIMUM FOR MAXIMUM TOUGHNESS AND EFFECTIVE STRESS-RELIEVING.
1025 550 63.5 65.1 66.8
1050 565 62.6 64.8 66
1075 580 61.3 64 65
1100 595 60 62.5 64
1125 605 58.4 60.5 62.4
1150 620 57 58 60.9
1175 635 – – 59
1200 650 – – 57
This is from Crucible. BTW Crucible's CPM M4 makes a better blade.
