- Feb 1, 2001
I'm a new maker and have a few questions about quench oils:
* I'm curious how long the oils last till it needs to be replaced? I'll be using canola oil mostly for 1084 blades.
* Can you contaminate the oil with normal use(get to much dust, slag, carbon, etc. in it)? How can you tell if it is no longer good?
* I just made a tank to hold the oil and it was rusty inside. I cleaned up all the rust and sprayed silicon oil spray to protect the bare steel from rusting till I put it in use. Will the silicon oil film on the tank walls contaminate the quench oil(canola oil)? Do I need to clean it off before filling the tank?
*Does canola oil prevent rust?
*And last, if I need to switch types of oils can I pour out the oil in the tank and fill with the needed different oil with out completely cleaning/degreasing the tank? Wondering again about contamination. I currently only have one steel tank for quenching but can use Rubbermaid totes to hold different oils. Just concerned the remnants of the previous oil mixing with the new oil is bad or not?
Any other advice is greatly appreciated!!!
