- Aug 12, 2008
Hello,
I am making a pocket knife based on the construction and style of those made during the Civil War era (built from scratch and I'm trying to make it as historically correct as much as possible).
I have finished the handle and my brother tempered the spring for me, but he doesn't know how to temper blades. Since this is a reproduction I want it to be tempered with methods used in the CW era.
But before I get into that, shouldn't the blade be annealed before tempering? I didn't hand hammer out the blade (I ground it, not authentic I know
), but I did have to heat it up about seven times to stamp the nail groove in the blade. A blacksmith told me he thought it might be a good idea to anneal to reduce strain and to keep it from getting brittle (he is not a knife maker though!). So, should I anneal it and how is this done?
Now questions on the actual tempering of the blade. I was going to use an old Sheffield recipe, but I want to see if it makes sense first (remember I'm a complete ignoramus). Here it is:
"After the marking, the blade is hardened by heating it red, and immersing it in water. In this state it is too hard for use, and requires tempering. The blade is now rubbed bright on one side with sand-stone, in order that the progress of the tempering might be seen. It is then placed with back downward on a plate of sheet-iron, which is put on the fire, and the workman very attentively watches the changes of color in the blade, till they attain to a straw colour approaching a brown, which is the test of the proper degree of temper; he then slacks(slakes) it to arrest further change."
Things that don't make sense (yet)
1. I'm assuming the blade is heated red and immersed in water after annealing if that is done?
2. Approximately how thin/thick is the sheet metal supposed to be that the blade is on while being heated?
3. End of process, slaked in what, oil?
If you can help me with any of this that would be great!
