So I have been having a little trouble with two things lately.
1. It almost seems impossible to get the initial scale of my 1080 off and get it flat. I am using good belts but it seems like the belts dont do anything after about 10 second of use. Once a ridiculous amount of time goes by trying to grind the flats flat, I start stepping up my grit an thats when I realize that the steel is still extremely uneven and I have so much further to go. I basically lay my flat bar stock against my belt and hold it with a magnet. That's how I grind the flats flat. Is there a more efficient way to do this or some sort of trick?!?!?!
2. When grinding the flats flat, I have been noticing streaks in the metal at higher finishes. Is this possibly the metal heating up slightly heating up (it's not a discoloration)? Is it a worn platen? I have been trying to finish grind the flats on a belt up to 600 or 800 grit. I am keeping the metal from burning during this process. What is going wrong.....I hope this problem isn't still related to problem #1. If so, then I will have to spend days at the grinder getting step one done.
Help! I'd like to hear how ohers go about accomplishing step 1 and 2 and what I may be doing wrong. Thanks.
