- Nov 26, 1999
This is what I've done so far:
I sanded the blade starting with 300 and went to 800. Then I buffed with a grey scotch brite pad first followed by the green.
I then washed the blade with Palmolive and windex. I heated the blade with water, dried and wrapped it in paper towels.
The apple cider vinegar was poured on and Seran(sp?) wrap was put around the whole thing.
Two hours later I unwrapped the blade, it was a light mottled grey with little circles here and there from the towel. I stopped the acid with baking soda, washed the blade again and oiled it.
This morning I repeated the process minus the sanding. Now the blade is mottled light and dark grey with less little circles.
What I'm trying to do is get the blade as dark as possible. It looks pretty cool now, almost like I found it buried in some old box. Am I doing something wrong? 4 Hours seems like it should have had a greater impact on the blade than this. Is there a better way to do this or should I just keep repeating the process?
Thanks in advance.
- D
Thanks in advance.
- D
