- Feb 5, 2013
I have a few questions I haven't been able to find answers to by searching.
1) I'm attempting to heat treat a hand plane blade - in this case much like a wood chisel in form. I'm using a two brick forge with MAPP, seems to swirl OK but I'm having trouble getting the overall front portion hot enough without the tip getting too hot. This is just intuition - the tip gets to non-magnetic much sooner and seems closer to yellow (I'm colorblind so I'm really not sure). The blade is 3/16 with a 29 degree bevel on the end.
What should I try? I think it is simply because the tip is thinner, not because of a hot spot. I do move it around a lot. Does it help to decrease the forge temp and let it take longer to bring the blade up to heat? What about coating the blade to even out the heating? Oh - can you still see the color of the steel through the clay? I assume the clay would be similar enough and that color maps to temp regardless of material, right?
I'm happy to experiment but I don't want to wantonly screw up steel if I can help it, so I guess my next question is: how much can I screw up the steel in experimenting? Does it sound like I'm reaching temps where decarborization or other damage is done? How much of a problem is it if it takes a lot of time and reheatings to actually forge something because, say, one has no clue what they're doing? (looking ahead there, not forging yet).
2) I picked up some sairset. It was only a few dollars for a small jar and available locally. Is it OK for coating blades? I have a second tool I want to heat treat - a woodworking float - that is quite asymmetrical and coating it was recommended as a way to reduce warpage. How long do I let it dry - either coating a blade or just coating the inside of the bricks so I stop gouging them? The thought of putting something with a moist interior in a forge sounds like trouble.
3) I've read that clay coatings accelerate the quench rate. That seems counter-intuitive. Did I read it wrong or could someone explain how that works? Somewhat similarly, does heated oil really quench faster because it is less viscous in the volumes we're looking at? I can see it happening with large pieces where convection becomes a bigger factor but it doesn't seem likely at this level. I don't have a clue about the validity of what I just said - it's just my gut feeling based on nothing much at all.
As always, don't hesitate to point me to a thread or sticky if these are answered already. I searched but that doesn't mean I searched right!
