I'm looking for a cheap pull-through sharpener with preset angles,this will be for in the field sharpening and until i get a sharpmaker.
I've been looking at the Smith's 2 step sharpener and the case xx pocket sharpener.
As another alternative,are lansky croc sticks any good?
I have been using it for about 12 years and I have always had razor sharp knifes. you dont know what you are talking about. I bought a factory one then copyed the angle and put the closer so you just have to pull your knife through and not having to worry if you are holding you knife at the right angle. I made my blocks about 2 inches longer to made the platform more stable when you are using it too.
DMT makes a product called the diafold..... check it out.
No offense but you may not know what you are talking about. What you have shown is not what everyone calls a pull thru sharpener. A pull through sharpener is hand held and quite small and have 2 pieces of carbide that scrape the edge into a terrible somewhat serrated edge.
What you have copied is similar to the Lansky crock sticks V sharpener or the Spyderco Sharp maker. Very different than a pull thru sharpener.
if that is so then why is all of my knifes are razor sharp??? first of all my handles are much bigger that what they have. every one that i have sold too has brought friends back to me to buy them. if it is so bad then why is every one that I have sold too is so happy with them???
so would a croc stick work? or is it a waste of money?
You are missing the point, re-read what I wrote. What you have made is NOT a pull through sharpener. You have made a sharp maker clone except with round rods and there is nothing wrong with what you have made. The sharp maker is well loved for a reason and, like yours, uses ceramic rods.
A pull through sharpener is different and uses pieces of carbide and are terrible. Here is what a typical pull thru sharpener looks like:
