Here's some recurves I've ground over recent years. These are all flat, but hollow ground recurves work on the same principle. These were all ground on a regular, flat 2" wide steel platen. The edge of the platen was used to feather the grind along, this works nicely if you shine a light in low and from the side towards you, so you can watch the grind side of the blade coming off the edge of the belt. The ability to continually see where material is coming off will let you, with practice, accomplish almost any grind you could think of. The fuller on the kukri pictured last was ground this way too, which allows bending or curving a fuller if wanted.
