Quick VFD question on motor selection.
Hey guys just as a quick question. I am sick of my single speed 1hp on my NWGS and am planning to run a 2hp 3 phase off of a VFD. Likely a teco since I am on a bit of a budget due to a new mortgage etc. my question is I currently have a 6 inch drive wheel, so what speed of motor would you recomend? Would I be better to go 1800 and overdrive it when I need to, or go 3450 and under drive it. I assume I am better off with an 1800 overdriven, but wanted to be sure. At 60hz I would be running about 2700 sfpm. How far up could I take it with that setup, and will I lose power by overdriving it? Thanks so much guys.
Grayser, I'm no expert but I bought a KMG grinder a couple years ago and they are set up with a 5 nch pulley attached to a 1725 RPM motor and a 2 1/2 inch pulley on the jackshaft which drives a 4 inch drive wheel at the belt. KMG so sells a 6 inch drive for those who want a faster top speed but most guys use the 4 inch. The guys that build the grinder in a box have to use a direct drive so they use a 3400 RPM motor direct to a 4 inch drive wheel. The KMG with the 5 inch belted to a 2 1/2 inch pulley doubles the 1725 RPM speed to 3450 RPM which drives a 4 inch drive wheel. It is about the same final speed for both set ups. With your grinder I believe you have to use pulleys to drive the belt so a slower motor would be better if you have a 6 inch drive wheel. This is just my opinion from studying the subject.
Thanks for the input guys.
Larry, my plan for this would be to hopefully eliminate the current pulley setup and run it as a direct drive. I'm certain I could make it work without too much trouble.
Grayser, I know of least on knife maker that converted a KMG to direct drive so I am sure that you could modify a NWGS to run that way. You might take a look at David Sharps blog. Just google it and you will see many pictures of his grinders including his direct drive mod. Take note that the shaft on a 3450 Rpm motor does not stick way out from the motor so your face mount has to be somewhat thin like 1/4 inch steel which should work fine and you may have to tighten the drive wheel a little further out on the shaft to make it line up. I think it is a simple system and might be better than jackshafts and pulleys or maybe it is such a small improvement that it may not be worth the effort. To me it is always fun to modify something and make it smaller and less complicated. Last I have a Kbac 27 d VFD which is the gold standard for most knife makers and they been selling for about 60% of what I paid a couple yeas ago. I found one for sale from an electrical supply company for $326 plus shipping just yesterday. It's your money but if it were me I would stretch the budget just a little bit and get the KBAC 27 D that is top notch equipment. Larry
I would love to get a kbac but being in Canada cost seems prohibitive. The cheapest I have found it will be over 500 once exchange and shipping is figured in. I can pick up the teco fm50 for 190 shipped, meaning the difference will just about buy the motor. Don't get me wrong, I know the kbac is what I should go for, but for the difference in price I will probably just build a dust proof enclosure. Other than on and off, it will not be adjusted that much, so I am not that concerns with ease of access for right now.
Try getting a quote at Motion Industries.
You can pick it up in person.
There is already a stock in Canada, so no need to ship them over the border.
