I cut out my scales, and pre-drill the holes for the rivets. Then stick some rivet stock or bolts in and tape the scales together tight( no blade). Next, grind the front to the curve you want and bull-nose it enough to make it curve up to the sides. Sand to at least 400 grit and buff well. This will get that area finished, as you can't shape and sand it after assembly. Assemble the handle and finish the handle sides as desired.
