You are in the wilderness, lost, and Rain is on it's way.
And you will have to endure a night of rain by the looks of the growing cloud cover.
I have seen numerous articles and documetaries about building shelters but they don't talk about Roof Construction, in great detail.
The mantra is "lot's of debris", should be as thick as from your hand to your elbow, that's about where it stops.
I have built enough houses, sheds, and barns to know that a steep roof sheds water better than a flatter roof. if it's pending rain, I'm making my roof steep. What is steep? In the eye of the beholder, I guess. I like using the 45° as a cut off. from 45° to 89° is the steep range. From 45° down to 0° is the shallow range. I would go for 45° at the shallowest to shed rain, up to about 60° up to 75° as closer to optimum.
First item to think about:
1. If it's going to rain, consider the pitch of your roof. Steeper sheds water better. Think of a teepee, Nice steep walls.
When you lay roofing shingles, you overlap, starting at the bottom and working up.
This is another thing I don't see mentioned much. Also consider the foilage being used. How does water run off of an evergreen branch? Rain water moves toward the tips of the bough and drips off.
2. For best rain shedding, start placing your natural material at the low end, and then work your way UP, always with generous overlapping. 1/2 Lapping is a good rule of thumb. Your first Row is placed at the bottom, your second Row, should overlap your first row by Half of it's length.
When placing evergreen boughs, remember, "TIP Side Down" , as this is the natural way that evergreens shed rain water. If you were using tall grass stalks or reeds, they shed water from tip to base, so place them to shed water as they would in nature.
Unlike a standard shingled roof, once you work your way to the top/ridge of your wilderness structure, you then start again, same theory, from bottom to top.
Don't dismiss Tall grass and reeds as a roof source. Thatched roofs have been shedding water for a thousand years. The down side is that you need a lot of it.
You can't always plan on being in an evergreen forest, so, keep in mind other sources. Thatch , sod , dry leaves , sticks, can all be used to put a roof over your head.
Steep sheds rain. Low and thick retains heat.
If you have the time, a little planning, and then a bit of careful execution can mean the difference between staying dry, or being dripped on all night long, or even worse, a complete failure of your roof structure.
