Raindrop damascus fighter
Hello, i want to show you my last work, it´s a fighter knife. The blade was forged from a 100 layer self-made damascus, from 1070 and 15n20 1,2 mm plates. Handle is made from goldfield wood, buffalo horn, brass, and a simple nickel/steel forge welded guard. In the next weekend i want to make the sheath, i will post photos.
I hope you to like it. Regards, Pablo.
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
Did you main your raindrops by drilling or another method?
In this case, when the billet was about 10 mm, i drilled it (about 3 mm depth drills with 8 mm) Then hammered to 5-6 mm (3 mm at edge) and, then stock-removed. I obtained better pattern removing a bit of material.
Did you hand-hammer or power hammer? I wanted to try raindrop but I was worried about cold shuts doing it by hand hammer and not a press.
Nice knife. Excellent pattern on the damascus.
For those who are wondering, "Goldfield Wood/Burl" is a commercial name for pretty much any species of Australian burl and other woods the seller has. This handle looks a lot like rib/flame mallee, but it could be she-oak, or a dozen others Australian woods..
I used a press for the forge-welding, but at the final steps (after drilling), it was hammered by hand.
Thanks all you. Pablo.
Thanks for showing this. i have some raindrop pattern damascus, and it's nice to see how the pattern looks on a finished blade. Very pretty.
Tere are some photos of the knife with the sheath. It´s very simply, made from cow leather and sting ray skin. Regards, Pablo.
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
I am in love with how the guard turned out. Care to share some tips on forge welding the nickel/steel combo? Does it weld like other damascus?
It´s very easy to weld steel and nickel, i think it welds at less temp than steel/steel.
Thank you. Pablo.
