Raise hands if you hate coating on a blade
Now a days, we see knives having coats of many colors especially in PVC. Back in the old days, all knives had no coating. Mostly good old fashioned polished or satin finished. Then military people started asking for a non reflecting blade. This promoted bead blasting or sand blasting. Problem with that one was that blasting promotes iron oxidation - basically rusting even on blades like CPM S30V. I noticed this just after a month in South East Asia on Trident Oblander 02 and Lone Wolf T2 ranger. Both knife showed reddish brown spots. Now, this gets worse where blade is not smooth. To my understanding, there is no such thing as absolute stainless knife. To have something like that, you have to remove iron from steel - which is impossible.
Japanese found a way by polishing the blade into a mirror finish by resisting rust as blades are simple carbon steel like 1045. When the blade has a very smooth surface, oxidation with Iron does not happen that easily. So, this solves one problem but creates another. High reflecting surface does not take any thin coating. When it does, it reflects light still even at very low light, even when blade is quoted in black. For example, CRKT and SOG’s tech bowie diving knife.
I raised this issue because I believe that a knife’s sole purpose is cutting. Out of all the jobs it does as a tool for camper, hiker, soldier etc. cutting is its main job. Currently, I see a lots of blade coated with PVC. That's coating actually hinders the blade’s main purpose. PVC coated does not cut well. I am not saying slicing tomatoes, but even chopping wood. It has a lot less performance than a naked blade. Quite significant if you measure it. Most of these blades are made out of carbon steel which rusts at the speed of light in Asian or tropical countries. For example, most of my TOPS knives. Even with a nice black coating, the edge rusts in matter of weeks. I've to reprofile the edge when I forget to take care of them. Now, tops coated portion is very good. A much better than PVC coating, and a lot thinner than PVC. Cuts better than the PVC coated blade.
To my experience, PVC coating is the worse especially when using the knife for its main purpose. Unfortunately, some of the best knife makers uses this method as it economical and faster process in production.
Chris Reev’s knife has this KG Gun Coat that has very nice finish. Nearly perfect, and very similar to bead blasting but without the side effects of rusting. But not as strong as it eventually comes off. So far best result I’ve seen is stone washed knives. Benchmade folders with stone washed even S30V steel did not rust at all while I was in SEA. But, not sure if it will work on Carbon steel.
So, let me know what you guys think about having the best coat for blade that will rust eventually (no matter how many numbers are there after CPM) but without the side effects of PVC coating. Blade can be non stainless steel, coating should be as smooth as the blade but will not reflect light, so slicing and cutting should be a breeze. I know, I am asking something out of the science fiction movies, but we should get something very close.
I took a course in business writing and I want to give you a little tip. When a person sees a big solid block of writing like that they get intimidated and most won't read it, put some spaces in there like this...
That way it looks less intimidating and people are more likely to read it. That's the same strategy businesses of all sizes use to get people to read their advertisements and other various business related writings.
As for blade coatings, I don't care for them.
It took a course in business writing and I want to give you a little tip. When a person sees a big solid block of writing like that they get intimidated and most won't read it, put some spaces in there like this...
Agreed Ph33r the wall of text. Space it out. But yes coatings have the advantages and disadvantages.
I didn't read your post, but I like some knives to have coating, but only to protect them from rust. I like Coatings more than rust.
Not a big fan of coated stainless.
Yeah the coating can help, I agree rust is annoying....makes me look like I don't take care of my tools.
From what I understand, there are two questions.
The first question was asking if we liked coatings on knives.
The second was asking if anyone knew of a perfect knife coating.
-I don't like knife coatings generally. I like the natural look of steal. I don't know enough about coatings to answer your second question though.
I'm not a fan of blade coatings, aesthetically speaking, but I don't find they impair function enough for them to be a real deal breaker. Still, I avoid them where possible because I prefer the look of naked steel.
I also like naked steel or satin if you will. I don't think there is much out there at this time that will hold up though. Most all the coating finishes i've seen tend to wear off eventually. Maybe the stonewashed finish you mentioned would be best. I don't have any experience with it though at this time.
I am not a fan of coated blades. I don't do covert deanimation in malls and I am even hard put to find uses for my folders, so rust and reflectiveness do not become problems for me. I like the look of naked steel, the more polished the better.
It has it's place but I prefer polished steel to coated. If it's prone to rust I'll put oil on the blade and take care of it - or buy stainless.
dlc coatings are micron thin and very scratch resistant. the issue here is price ...
I prefer satin blades....
Of course I prefer stainless steel...
On carbon steel I prefer coating than rust...
Thanks "pwet". I just looked at DLC (Diamond Like Carbon), and found to be very strong. Used on military application, also on Swiss Army watches. Question is, is it better than KG Gun Coat. because the finish looks similar. On the web-page claiming 83 years of life on no rusting. Anybody knows who uses this DLC coatings for their knife exclusively?
Thanks for narrowing it down for me. :thumbup:
Updates from knifeart about DLC:
[FONT=arial, helvetica](Tungsten DLC coating) This is a surface coating that has a molecular bond with the blade. The coating has a hardness of about 88 HRC, even tougher than our blade steel, and wears beautifully over time and use.[/FONT]
I don't exactly hate coatings, but I'm really not a fan of them for sure. I very much prefer non-coated blades.
Of those I have experience with, which isn't many, the only one I have any respect for is the coating on my RAT RC-4. It seems pretty tough and is holding up well. Unfortunately the coating is one of the reasons the RAT isn't a favorite of mine.
Coatings have their place I suppose, covert military op's, or to protect non-stainless blades from corrosion. But I'll take a nice patina, and a bit of oil on a blade, over a coating any day of the week.
Kevin
