Randall 14?
Has anyone who has owned a Randall 14 ever had a problem with the epoxy that holds on the micarta handle separating? Thanks in advance.
No problem whatsoever and I've put mine through more than the average Mod 14.
First I bead blasted the blade and exposed tang, then put the whole knife in an acid bath to thoroughly clean it, then into a parkerizing solution (~350 F), then into a fresh water rinse and then light oil. That was almost 20 years ago and the knife is still in great shape, although the collector value is somewhat diminished. :rolleyes: Micarta is tough stuff and the epoxy holding it has shown no weakness at all.
They use a high strength epoxy. You'd probably have to saw the handles off to ever get to the tang.
