Man you sure got that horizon level in that pic
Check the eyes...Looks pretty identernal to me!
wait. there are TWO of you?View attachment 1894228
Look at this cool picture I took last night at 10:30 with my phone. I guess there was a smudge on the lens that created a streak on the moon over the view of the Atlantic Ocean from an area of the North Carolina coast that faces due south.
Drinking beer and hanging out with my twin brother, who I don't get to see very often anymore.
I think I'll leave that one alone for nowMan you sure got that horizon level in that pic
Check the eyes...
I suspect foul play.
Well, all that...and raisins in rice pudding.What is weird is that despite centuries of people knowing, understanding, and utilizing the curvature of the earth, there are people who genuinely believe it is flat. This and other clearly false beliefs make me worry about humanity sometimes.
If that object is relatively large and you are relatively close to it, the curvature of that object will not be physically apparent
oh c'mon, what has a raisin ever done to you? Partially rehydrated raisins in either tapioca or rice pudding are like the friendliest thing everWell, all that...and raisins in rice pudding.
Partially... rehydrated... raisins...oh c'mon, what has a raisin ever done to you? Partially rehydrated raisins in either tapioca or rice pudding are like the friendliest thing ever
I still get nightmares...oh c'mon, what has a raisin ever done to you? Partially rehydrated raisins in either tapioca or rice pudding are like the friendliest thing ever
Like the other observable planets in our solar system, the Earth is spherical shaped. In fact this is pretty much the only shape that it can take due to the nature of physics and planetary formation.
The effects of gravity are observable both on planet and off. Gravity will create a force normal to the surface of the object.
If that object is relatively large and you are relatively close to it, the curvature of that object will not be physically apparent. Particularly when the signal to noise ratio is poor such due to the imperfect undulating surfaces that make up a planet with plate tectonics.
According to Google:
"Visual daytime observations show that the minimum altitude at which curvature of the horizon can be detected is at or slightly below 35,000 ft, providing that the field of view is wide (60 degrees ) and nearly cloud free."
It isn't weird that the horizon appears flat when you're close to the ground. The Earth is pretty big. And, due to the boundary air layer that is typically above the ground or water, light can bounce a pretty good distance across the surface. We're all familiar with the visual effects of a mirage, and are not confused by its existence.
