- Aug 21, 2014
you guys wear underpants?Be sure to wear thick underpants boys.
Suckers
is 'suckers' a suggestion?you guys wear underpants?
Suckers
only for my wife. sorry dudeis 'suckers' a suggestion?
airplanes dont have to adjust flights for the rotation of the earth.
if they did then it would be impossible to land on runways going perpendicular to the rotation.
airplanes have to adjust their flight path to account for the rotation of the earth?![]()
Yes, Timmy - airplanes do have to adjust their flight, both for rotation and for the fact that the Earth is a globe, not a flat piece of land. I'll add 'navigation' to the list of things you might want to read more about.
Super light stamp on this one. 3v is barely legible. I guess we should throw it away.
They navigate by moving through the atmosphere, which is also moving as a result of, and in rotation with, the Earth. And while this is generally true, airplanes (just like ships) also use weather phenomena to their advantage, such as the Jet Stream. No rotation of the Earth, no Jet Stream, no ocean currents, etc. Travel in the opposite direction of the Earth's rotation, you are also going to generally be moving against prevailing global weather currents, which affects flight times, fuel consumption etc. The Earth's rotation, and more importantly - it's resulting effects - definitely factor into navigation. These very real phenomena, which present travel advantages and challenges, wouldn't exist without rotation.airplanes have to adjust their flight path to account for the rotation of the earth?
yes or no?
you are doing a lot of people like that. I just thought you should know.View attachment 2204061
Can't wait to play "Boar on the floor" with the new guys this weekend
Or why his nickname is "Peggy"
Omfg I'm spilled my beer hahahahahahahaOnce the sausage comes out everyone will want to play
