Random Thought Thread
I'm having a middle back back spasm right now.
*Sad
It's okay and under control and I'm sleeping okay so I am on the mend. Thanks for asking.
You should try an accupressure pad. Spoonk is the best brand I've found.
At first, you'll want to lay on a softer surface, like your bed when using it. You'll want it to be against your bare skin if you can tolerate it. Until you get accustomed to it, the first 60 to 90 seconds will feel uncomfortable and it may cause an agitated feeling to rise up inside you, like a mild anxiety. If you just breath deep and relax, it will go away and then your back will start to relax.
There's no time limit you can lay on it. Often times I fall asleep on mine because it's so relaxing.
I was having issues with my back yesterday and they're pretty much gone because I used the accupressure pad for a couple hours. It slay
I've had several people try it and everyone that has says it's pretty crazy how much it helps. Give it a try.
The Delta protocol is one of the low temp tweaks. I was doing development work on the low temperature tweaks (a heat treat that does not use the secondary hardening hump and addresses retained austinite through rapid quench to cryogenic temperatures instead) for years. Keffeler was also. This is how we got to know each other.
There was a batch of 3V that did not have normal heat treat response. This was back when I was making the original Shiv many years ago. I had done experiments with prequenching D2 with excellent results and I applied what I knew from D2 to 3V and it addressed the issue. But not for the reason that I thought. (prequenching is performing a heat treat on a complex steel at a lower aust temp and then performing another heat treat at a higher aust temp. This has the effect of reducing grain size but it is risky because it is possible to dissolve the carbides pinning the grain boundaries and actually have explosive grain growth if done improperly. This is specific to complex steels whose grain size is otherwise baked in) It turns out that an anneal carried out over a 24-hour period was all that batch really needed. I suspect it was highly spheroidized which affected the availability of carbon to go into solution and had an effect on the final heat treat. Interestingly, this problem could not be found with a hardness test, it was only apparent in an edge stability test which is where I noticed it, Dan noticed it, and Guy noticed it. Because we were all testing our work and we saw the problem. The problem was probably not even noticeable to folks using a high temperature protocol (The standard for tool and die) not because it wasn't present, but the standard heat treat was already chippy mushy and would have appeared relatively normal. The three of us went together and did the work to do an exhaustive development cycle with the heat treat of CPM 3V. I spent most of one winter solely on this process. I'm not a metallurgist. Other than a couple materials and processes classes I took at NC State back in the '90s, most of what I know about metallurgy is from the internet and books. But I had a significant professional background in product and process optimization at this point because I had just come off of a 10 year stint at TecRep Engineering as the product design manager. We had a process of creating a matrix of variables and (more or less blindly) modifying variables and measuring both the outcome and the interaction on each other. The best example of this was our foam generator development work we did for a chemical company in Greensboro. But that's another story. But the process for developing the Delta protocol was as simple as introducing and modifying variables, the timing of steps, adding steps, and effectively evaluating the outcome which meant standardizing on a sharpening angle, test media, and eliminating variables such as overheating the edge etc in an effort to maximize the signal to noise ratio. It is a very stringent process based on observation and comparative testing kind of like the Mohs hardness scale where this mineral scratches that mineral. You have test standards and you run them all through the same media and then you look at the edge under bright light and magnification and objectively observe which edge has accumulated the most damage - edge loss. I had run D2 through this process before. The most significant finding that I can share with you is that abrasive wear resistance is largely built in, toughness in 3v is largely baked in unless you screw it up (which is entirely possible which is actually why I started making videos in the first place, to demonstrate that I had not screwed it up) and that edges don't really go dull through just abrasive wear but through edge loss-damage that can be summarized as edge stability. Which can be broken up into fine edge stability and gross edge stability. Conventional 3V has a chippy mushy edge. When using the secondary hardening hump this is due to a soft weak carbon lean martensite attempting to support a growing carbide volume fraction. This is why I don't like edge retention testing that is based on where resistance such as lightly sawing at abrasive cardstock to try to determine which steel and heat treat have the best edge retention. That isn't edge retention for most people. But I digress again.
I did the majority of the work and claim credit for the development of this heat treat, but the three of us went in together and the three of us have access to that protocol. Peters was not able to duplicate it at first and had to make some changes to their process equipment but after a while they got there and they are frequently able to apply the process better than I can now, depending on the knife geometry. Probably because my heat treat set up is worth about $5,000 and theirs is about half a million dollars.
There have been improvements to both the steel manufacturing process and the heat treat process since we originally released the new Delta protocol, if anybody has noticed, the work today is the best it has ever been.
Anyways. Very long story short. The early low temperature tweaks were being openly discussed on this very forum and also hype free blades and some other places and those original low temperature tweaks are freely available at Peter's heat treat, and their heat treat is particularly well suited for it after their development work with us with this particular steel. They're good at it.
So, when they are saying they are using a variation of the delta protocol, this is essentially true. They're using one of the low temperature tweaks that we used to use that is freely available to anyone who gets their work heat treated at Peters. It is a very good heat treat. The Delta protocol is measurably better and (also very important) very consistent from heat lot to heat lot. But the Delta protocol is not enormously better than the available low temp tweak at Peters. It developed from it, they are related, and you would have to have two identical samples in hand side by side to see the difference in use. I have no problem with their statement.
*Sad
I was down for a couple days 2 weeks ago. Wife thinks it was from snowmobiling but it wasn’t. Can’t wait to go again tomorrow. 🤣
Anyways, back problems suck. That and tooth pain is about the worse.
We're kinda snowed in, but it's going to stop in about 16 hours (noon tomorrow MTN time).
About 10 hours ago...
That second photo is really great. Thanks for sharing it.
I was last in Roland's new home town in 2000 on the way to visit Rob Simonich up in MT. We spent the night after a long day on the motorcycle riding up from Beaver Creek, CO.
I love WY but the cold, wind and snow would overwhelm the missus. LOL. (The Wind Rivers were where I learned climbing and mountaineering.)
I would like to say.....
HAPPY FRIDAY
we made it through another week!!!!
Some of us had good ones some bad ones (I hope it gets better for you soon)
But we made it
Grab a beer buy a friend and enjoy this little victory in life
I'd post a pic from a hosting site... but I've been drinking lol
(And some how just keep linking to that hub site us guys use hahaha)
The response here has been loud and clear and I think I understand now that the pre-orders are more important to folks than I realized. :thumbsup:
I used to provide an eta text and email message to every customer I had, every day, for every job, and every route. It listed an exact time based on gps routes and historical job data. Very scientific and data based. About 95% accurate all said and done even considering traffic patterns since it incorporated Google maps.
99% of people loved it. 2 people left me shit Google reviews saying we were an hour or so late or early so I removed it from my automation. We had at least 150 calls the first two weeks asking where it went.
All that is to say I feel you. Also to say I put it back in play two months ago.
Shine on.
I had to drop 2300 on my car today.
I'll start digging up tomorrow.
On the bright side I found this while cleaning the garage
Nathan the Machinist Nathan the Machinist must have dropped it looking for not painkillers
or something less stupid than that idk
The legendary 10mm......plus deep well?!?!
Sucks about your car, but look at the positive!!!
You got that 10mm!!! 🙂🙌
I've spent the past couple days figuring out my work space, installing the lift, etc at my new job. Today is my official first day as 'Lead Mechanic', (there's only just me, lol) at The Bike Shack- Sooke's new high end mountain bike shop. The industry is in utter chaos, but if my boss is smart, (he appears to be, he hired me after all, lol) he'll find opportunity in the mess.
I'm excited about it because having enough income coming in to pay the bills takes a ton of pressure off me to make and sell knives and sheaths, which is the feast/famine type situation I've lived for the past 3 years. I'm at the shop two full days a week to start, leaving me with plenty of time in my home shop to make knives and sheaths. All the money from my knife and sheath making can go into tools- instead of groceries- which will make my life easier, and my work more efficient, with higher quality to boot!
After everything that went down with my bike shop, I never thought I'd work in the industry again and I had made peace with that. This job, though, is a unicorn- a good, fair wage, reasonable and flexible hours and I'm valued for the knowledge I've amassed after 30 years in the business. Also, the shop is less than 10 minute bike ride from the trailhead, and a 15 minute ride from my house. There is also a brewery right beside the shop, so when yoko yoko comes for a visit he can stay properly lubricated! GEONBAE!
