1. Ranger RD7 in 5160 with customized grips and nylon sheath. Used a few times, polished the edge bevel up (Did not change the edge thickness).
TRADE PENDING2. Spyderco Military, PE S30V satin finish. Brand new S30V Millie, most recent version with fine jimping and dual liners.
TRADE PENDING3. Spyderco Manix, PE full size. Like new except the edge is polished up and lightly thinned out for a more convex profile.
4. Spyderco Paramilitary. It started as a PE satin finish S30V Para, the most recent version with the fine jimping. Then I had a custom tip up wire clip installed. I modded the handle slightly because I couldn't get a full grip without using the index finger choil otherwise. I also reprofiled the blade to a much thinner edge. Cuts extremely well.
5. Spyderco Yojimbo, blue G10. This is a user Yojimbo. The knife was recently stripped down, cleaned, lubed and sharpened. The action is smooth, lock up secure and the edge will easily shave. The edge bevel was convexed and polished, giving it a thinner edge that cuts much better. There is slight vertical play, but the lock still holds securely. From what I know about compression locks, the play could be adjusted out.
6. Spyderco Calypso Jr. ZDP189. Given a very thin convex grind that cuts extremely well.
7. Spyderco Cricket. SPF
Additional photos can be requested through email.
Looking for:
Mostly just Busse, Swamp Rat and Scrapyard Knives
Might consider certain Spydercos (CF Millies, Lil T, Stretch 2, Street Beat...), Bark River and Fehrman
