- Oct 3, 1998
In the Steel FAQ thread, Jason (medusaoblongata) mentioned that the FAQ didn't really clearly answer the main question people went to the FAQ for: to understand which steel is better than which other steel. There are many problems to answering this question, but the main issue boils down to: in order to do a clear ranking of steels versus each other, it is necessary to oversimplify to the point that such rankings are badly inaccurate with respect to some property or other.
That said, I decided to see if I could give a basic feel for steel properties without compromising accuracy too badly. I started with just the stainless steels. Please let me know what you think. Note that I had to use rather coarse groupings.
Here it is, let me know if you think the oversimplification is so bad as to make this counterproductive:
Because stainless steels are often heat treated to around the same hardness
(i.e., 440C is usually around 57 Rc, ATS-34 is 59-61 Rc, S60V is getting
consensus at around 56 Rc, etc.)
it's a bit easier to give a general feeling of the performance you'll get from
different classes of stainless steels, without introducing too many
inaccuracies. Here is a general categorization of stainless steels:
420J and 6A represent the low end of stainless steels. They are very stain
resistant, and are tough due to being very soft. However, they are also very
weak, and not very wear resistant. Generally speaking, expect these steels
to lose their edge quickly. 6A is finer-grained and takes a sharper edge,
due to the vanadium content.
440A, 425M, 420HC, 12C27, 8A, Gin-1, ATS-55 represent the next level
up. They can get harder and stronger than the previous group, and are
generally more wear resistant. All are very stain resistant (less so than
the previous group), though ATS-55 lags badly in this area.
All are getting to the point where wear resistance is getting okay.
A few points worth noting: 12C27, due to its purity, can perform really
well when heat-treated right. 8A is the finest-grained of the group and
can take a very sharp edge. Gin-1 is probably the wear-resistance
champ of the group.
440C, ATS-34/154CM, VG-10, and S60V are the next group up. 440C is more
wear resistant than all the previous steels mentioned, but not quite in
the same class as the rest in this group. However, it is tougher and more
stain resistant, though it's also weaker. It's difficult to make generalizations
about ATS-34 and 154-CM -- they are in such widespread use that heat
treat varies widely. These steels provide a high-end performance benchmark
for stainless steels, and hold an edge well, and are tough enough for
many uses. They aren't very stain resistant, however. VG-10 can be
thought of as being like ATS-34 and 154-CM, but doing just about
everything a hair better. It's a little more stain resistant, tougher,
holds an edge a little better. And VG-10 has vanadium in it, it's fine-grained
and takes the best edge of this group. S60V has by far the best
wear resistance of the group, though consensus is becoming that it
should be left around the same hardness as 440C (56ish Rc), which
means it will be relatively weak compared to ATS-34, 154-CM, and
VG-10. S60V is the winner here when abrasion resistance is much
more important than edge strength.
BG-42, S90V, and S30V constitute the next group. BG-42 has better
wear resistance than all the previous steels except for S60V. It is
tougher than ATS-34, and more stain resistant. It is wear resistant
to the point where it can be difficult to sharpen. S90V represents
the ultimate in wear resistance in the steels discussed so far.
Also tougher than ATS-34, and more stain resistant. It can be
very difficult to put an edge on. It is difficult enough to machine
than it is used almost exclusively in custom knives, not
production knives. In your buying decisions, you might want to
take into account the difficulty of sharpening these steels.
S30V backs off on the wear resistance of S90V,
but is significantly tougher and easier to sharpen. It is more wear
resistant than BG-42. The jury is still out, but it may end up this
week's ultimate high-end all-around stainless steel, due to
high performance coupled with easier machineability and
sharpenability than the other steels in this class.
champ of the group.
