There are different categories.
Non-stainless:
INFI then SR101/D2 then SR77
The closest comparison to INFI that I know of is CPM 3V. Very tough with good wear resistance.
101 is basically 52100, so you'll find more about that with that name. It may be slightly modified and with a great heat treat.
Same thing for the sr77 and S7. These are shock steels. Great for impacts.
CPM 3v is almost as good with shock, while being between D2 and M4 in wear resistance.
Stainless:
S30V is the best stainless listed
154cm, bg42, and ats34 are all very similar (154cm is USA version/ats34 is Japanese version of same steel)
These are all decent steels. Old recipe, easy to sharpen, will rust with neglect. Don't confuse 154cm with CPM154. While they are the same formula, CPM154 uses Crucible's particle technology and will be similar to S30V.
There are 3 big things with steel: corrosion resistance, toughness, wear resistance. With the carbon steels you listed, you give up corrosion resistance for the other 2. Same trade with the stainless steels. You lose toughness for corrosion resistance.
