I've been borrowing my bf's Spyderco folder for the past couple of years and would like to get my own for an EDC. His is many years old and is no longer made. (edit & correction: we just did some digging and his is the 1995 CO95 Copilot with full serration, shown here and here... kind of like the Dragonfly mated with the Delica). That's out of my price range so I've been looking at the entry point Byrd knives.
(edit and update)
I originally settled on the Byrd Raven or the Byrd Catbyrd. But have since decided that I'd like to get a simple flat grind now, saving some type of hollow grind for later when I can afford a higher end Spyderco. So now it's between the Byrd Catbyrd and the Spyderco Tenacious (pics & info below). Both come in combo edge, use the same blade material with a similar blade size. The blade shape, handle shape and handle material differ between the Catbyrd and Tenacious and I'm not clear how that affects use and performance. I'd appreciate any advice you may have.
I just need an all-purpose folder, nothing specialized at this point. Something to use for camping, bugout, general "I need to open something" knife. I've read good reviews on the Catbyrd. It sounds like the flat grind makes it the kind of knife that can take a lot of abuse and will last for years. eta: I've read similar things about the Tenacious. (I haven't seen as much on the Raven. It looks like a knife with more versatility, also requiring more maintenance.) Since I don't have an in-depth understanding of the benefits/uses of each, I'm not clear which would best suit my needs as an EDC starter knife.
Byrd Raven
- $37.59
- clip-point blade
- 8Cr13MoV stainless steel
- centerline grind
- some type of swedge or second edge on back of the blade
- liner lock
- blade length 3 1/2" (89mm)
- blade thickness 1/8" (3mm)
Byrd Catbyrd:
- $46.95
- clip-point blade
- flat grind
- looks like a small bevel on back of the blade
- integral LinerLock (Chris Reeves design)
- blade length 3 9/16" (90mm)
Spyderco Tenacious:
- $49.95
- leaf-shaped blade
- 8Cr13Mov stainless steel
- flat grind
- textured spine jimping
- Walker LinerLock
- blade length 3 3/8" (86mm)
(edit and update)
Byrd Raven
- $37.59
- clip-point blade
- centerline grind
- liner lock
Byrd Catbyrd:
- $46.95
- clip-point blade
- flat grind
Spyderco Tenacious:
- $49.95
- leaf-shaped blade
- flat grind
- Walker LinerLock
