I somehow missed the replies in this thread, so I will play catch up.
Steel supplier is Sullivan Steel in New Jersey... they specialize in 52100 bearing quality steel which I believe is manufactured by Ovako Steel in Norway.
My heat treat process is nothing new. I do the usual things to refine the grain after forging, (either multiple normalising , or sometimes multiple quenching x 2..before the final quench harden).
Use a digital oven/kiln and all my thermal and hardening heats are set at 1550F.
I have been experimenting with soaking at 1550F to see what happens, no noticable visible grain growth, the Rc hardness has increased from my shorter soaks..
The figures quoted were square sample pieces (full quenches)....I am quenching blades tip first and getting the same results (on the ricasso and tang) ...it seems to me that this gives a slightly faster quench than a full austenite edge quench where the heat is retained in the spine.......so a full quench in my shop relates to a slightly harder 'as quenched' blade.
My tempering temperatures have had to increase to 500F + to bring the hardness down to the 59/60 range...and the blades are almost blued by the time the tempering has finished!
Yeild strength.....I have found that my full hardened blades that have been tempered (to Rc 60) will flex to around the 45 degree mark and return to true without any additional temper designed into the spine... pass 45 and they will snap.
I use Chevron 70 quench oil at 140F ambient...a medium to fast quench ( slightly faster than Texaco type A).
Steel specs as supplied from the manufacturer ..(I buy in bulk....been using this same stock for the last 3 years).
C .98
Cr 1.39
Si .21
Mn .27
P .011
S .009
N .17
Mo .05
Cu .182
V .004
AI .030
Ti ppm 7
O ppm 4.2
Bill..You can of course send me any samples for testing, but if they are pretty , then you may not get them back...
Ray...May see you at Batsons, but definately Blade.
PimpinSquee...I will send you another email
Kevin.
