Re-affirming Pitdog's test
kgd
I was thinking about Pitdog's test of the convex and scandi-grinds last week. Problem was I never had a scandi until yesterday's little score of that Jimi Wade necker. So today, after picking up 3 weeks of dog poop, I put the Breeden Kat and Wade Necker to a little contest.
The contestants:
Breeden kat: 3.5" blade, 3/32" thick O1 steel; full flat with V-grind secondary bevel at 15o per side. Osage handle material - nice and comfy.
Wade Necker: 2.5" blade, 0.125" thick, 1075 steel. Scandi grind with slight V-grind secondary bevel at 15o per side. Handle - originally OD green paracord. Replaced with yellow braid so my wife wouldn't keep telling me it was too tactical looking (Jimi's wrap was nicer looking).
The activity - just some notches and stick sharpening of a fresh American beechwood branch.
The necker's scandi grind really excelled at controlling the sliced cuts into the notch. The knife just seemed to want to lay flat against its bevel and it was easy to take nice even slices. Another bonus was the thicker blade (0.125") which was easy on the thumbs as I pushed against the sides.
The Breeden didn't perform quite as great at this activity. It did an adequate job mind you, but I had less control during the wood slice. The blade kept wanting to dig deeper in the wood as I sliced, not having that convenent 'scandi bevel' on which to sit and orient the blade through the cut. The thinner blade was also a bit harsher on the thumb at the spine.
Both knives were equal on the sharpening the points. The Breeden edged out here because of the comfort of that nice fat handle.
Overall - the Breeden is a far better general slicer and cutter in the kitchen and for twine and cords. The thin blade coupled with flat grind and comfy handle make it great at these tasks. Where it lost out was the comfort on pushing on the spine and control of it slicing in wood itself.
The Wade Necker really surpassed my expectations on its ability to slice into wood at notching. I just didn't believe that this thicker little chunk of metal would be able to cut wood better than optimized cutter but it was more controlled.
Great review and comparison, kgd! Not to mention the great pics! :thumbup:
That little necker looks pretty neat. I think it'd look real spiffy with a blue paracord wrap. ;)
Cool thread. That osage looks to be aging well in the short time you've had it.
That is one place where a thin blade can be annoying, when the thin spine wears on the thumb.
-RB
Great pics Ken ,
Glad to see that little guy work for you, I am putting in an order for some different colour 550 cord and maybe some g-10 this week to change things up a bit, as these are a design in progress let me know what you like and dis-like for the next ones coming.
thanks
and
cya
jimi
Hi Jiimi,
That necker is a solid little chunk of steel. Everything about it is pure heavy duty including the tip of it. It would probably make a great thrower also. Keep the scandi grind because that is a really unique twist on this necker - and it works excellent!
I think it would work great with G10 slabs. I would keep them on the thin side and give it some texture like the ridged spyderco slabs on the military. For the paracord, if there was a way to keep the kydex from needing the wrap for retention purposes than that would be useful i.e. you would have a usable sheath if you needed to use the wrap from the handle for an emergency purpose. Although, I had no problems with my re-wrap and sheath retention, just gave the kydex a bit of heat with the hair dryer and it accepted the new wrap easily.
I will probably do a bit of sanding at the edges of the end of the tang surrounding the lanyard hole just because my hand tends to contact there. Other than that I really like this knife. I'm going to EDC it for the next couple of weeks just to see how it performs on common things like cutting boxes and other stuff. Yep - it will be with me on the Detroit River today!
