Hello guys
I made a blade from O1 steel last year.It already hardened but not drawned yet, it just sits in the canola oil for months.
I want to know: could I repeat all the process of heat treatment from the beginning? Thanks in advance.
Frids
As Keith pointed out, some folks triple quench O-1, but then some folks also drink strychnine and handle snakes in church... personally I would need some real good reasons to follow suit before dropping my hymnal for the jar or a rattler.![]()
Kevin,
If I could figure out how to add a sig line, this quote would be in it.
Josh
I don't know why (wish I did), but it seems like the more alloys a steel has, the more it "dislikes" being quenched more than once.
- Mitch
Perhaps in terms of distortion, but with a little alloying it will show differences a bit more. If your method of heating falls short of what is necesarry each heat and quench will pull a little bit more into solution and then lock it there so by the third cycle you could be approaching what an accurate and well controlled austenization could have done in one heat. Simpler steels will not show as much of a differnece because they will go into proper solution easier.
As I previosly stated, this is a bit of a catch 22. If the blade was hardened properly it will most likely not have faired well without a temper, if the initial hardening was not so great it could be all right but may require a proper hardening this time.
you are making me wonder if now only on 3rd quench you were able to straiten the blade out but now it's not hard.. did you check if you got it hard that time?
could it be,, you didn't nail the quench on the 3rd time around ?
or did you over heat it three times burning out your carbon ?
heat treating 01 3 times shouldn't hurt it but heat treating it incorrectly on the 3rd time can un-due what you did the last time treated for sure, we know that..
try quenching again making sure it's hard if you didn't on that time befor
just a thought...
wondering now ?
did you check the spine of the blade to see if it was soft as the edge also? I'm sure you wouldn't have burned out the carbon from the spine where it's thicker, or is the whole blade that thin? if it was soft also, then you have another issue other then thinness and burn out
would be my thought..
if my o1 blades are to thin they normally ripple at the edge if they don't ripple they are thick enough at .030 or more depending the use of the blade in it's new life is good for mine.. then grind any dead skin off.
