- May 19, 2009
Ok, i'll just stick with tung oil or boiled linseed oil, then maybe a rubdown with 000 steel wool. Last question: what shall i use to fill in any gaps between the handle and tang? At the bottom of one of my ASTKs, the handle has maybe a 1 mm gap between the wood and the tang. And should i fill it with whatever before or after i treat my handle with tung or boiled linseed oil? cheers!
I had a fairly small gap between the handle slab and buttcap on my replacement satisal m43 that arrived the other day. Here's what I ended up doing: since I had to sand down the handles to get the rogue off before finishing, I did the sanding over a piece of printer paper to catch the dust. I sanded a good bit with 100grit to get a decent amount of it. I then mixed this stuff with a very light amount of wood glue and used it to fill the gap. Allowed it to dry, then went ahead and continued sanding: 150, 220 then 400 grit before cleaning and the first coat of Tru-Oil :thumbup:
