- Nov 14, 2018
I was just wondering if it is possible to reprofile a blank that has already been heat treated to 61hrc? Using and angle grinder or my belt grinder? Looks like many mixed ideas on this topic
When you grind/reprofile tip of knife , start grinding FROM tip and towards plunge .Do that way for both side spine/belly . That way less temp will be accumulated around tip . Tip of knife have not much steel so it will easy overheat if you are not careful . . .I was just wondering if it is possible to reprofile a blank that has already been heat treated to 61hrc? Using and angle grinder or my belt grinder? Looks like many mixed ideas on this topic
That s way I recommend and I use 80-100 grit for that kind of work .Nothing is wrong with your belts ..every 40 grit belt will do the same ,pure physics .Small surface for grinding low number of grit make contact with steel /because of size/ and dust all over .It s like you file with file for wood thick on spine 2mm woodIt went really well. The belts don’t hold up to hardened steel very well when I first started grit from the belt was flying all over the place. However it worked!! Thanks again
I’m not trying to stir anything up here but I have been reading that norton and 3m belts hold up way better than others? Has this been your experience also?
I don t think that 36 grit belt is best choice for profiling / maybe WORN one properly fractured not glazed / thin blade . Especially not on flat ceramic plate behind belt .Try higher grit and you would be surprised...On which speed you run your new grinder ?
I profile my kitchen knife /1.5-2mm / on 100 grit zirconia belts and they last forever . . .. .
Order some carbide boys from usaknifemaker.com. Go slow, use oil, and clamp it down to a solid backer like an aluminum or mild steel plate.Indeed thank you!
Any idea what type of drill bits will cut into 61 nitro v? Mine only make a tiny divot
