Re-profile blank after heat treat?
It went really well. The belts don’t hold up to hardened steel very well when I first started grit from the belt was flying all over the place. However it worked!! Thanks again
I’m not trying to stir anything up here but I have been reading that norton and 3m belts hold up way better than others? Has this been your experience also?
TruGrit has a Norton Budget Belt that I find to work great & be at a great price point! I get 1-3 blades per belt depending on size, I grind after HT and then use them for profiling etc .. What Hoss said is a 100% correct! Buying cheap belts cost more in time & hassle for not as clean of a finished product!
Natlek i used a carbide bit it still took me a very long time but I did get it done
What kind of carbide bit you use ? Solid carbide drill should drill like in butter , masonry drill are not sharpened for steel , ceramic tile bits a sharpened in right way and will drill in steel like in butter .....
Check this .......
https://www.bladeforums.com/threads/drilling-hardened-steel-easy-cheap-way.1625415/#post-18570049
https://www.bladeforums.com/threads/sharpening-masonry-drills.1540592/
Here I drill hole in 67 HRC HSS steel , with drill bit for ceramic tile . . .
