Brian Jones :
One could make a hwak or hatchet speifically for chopping
only.
Tomahawks are a subclass of hatchets which are a subclass of axes. If you
make a tomahawk that was optomized for chopping you would end up having made
a hatchet. To be clear there are specialized hatchets that are not made to
chop, carving and such, but you don't use them for general woodcraft because
the bit is too thin, with too extreme a curvature, and they are not the
topic of discussion here.
utility, skinning, and defense (natives, etc.), the hawks would far
outclass the hatchet as an all-around tool for use.
Note chopping is not all hatchets are made to do, they are also used for
many cutting chores at which they will outperform a tomahawk (that it
designed for throwing and/or combat) because of the ability to use a thinner
bit and higher grade steel, as well as difference in the head profile and
handle will lower fatigue and raise comfort and security. The hatchet will
also have a much longer edge retention and much higher cutting ability /
durability ratio.
In regards to game, butchering is very common with an axe. Generally the
only difference between a hunters axe and a wood craft one will be in the
handle (much more aggressive texture unsuitable for chopping as you can't do
a smooth two handled stroke) and poll (for flaying). The head profile is the
same. With the exception that a soft wood axe will have a bit that is too
thin for bone.
In regards to combat, hatchets are generally unsuitable as there is too much
risk of seriously damaging the edge as it is not made to take that level of
impact. It would be like using a fine hunting knife in combat, while it will
cut very well, it does not have the required level of durability. As well
replacing the handle on an axe is very difficult as while this is one of the
primary goals of tomahawks it isn't for axes..
It wouldn't be expedient for someone to carry several axes or
hatchets for different tasks in the woods, right?
Anyone who uses them as their primary tool does as you don't use the same
axe for splitting as you do for limbing, debarking, root clearing etc., nor
would you use a limbing axe for felling etc. . In you are in a group the
tools are spread out and different people do the various tasks. If by
yourself you do them step by step. First off for example you clear lanes,
limb the trees, clear roots, debark if necessary. Then you switch to your
felling axe and knock them down. Back to the limbing axe (swamper) to clear
them up.
In fact it is usually more restrictive than that because you don't use one
type of axe on all types of wood. An axe that is able to cut hardwoods is
wasted on soft woods as it won't get the penetration that a soft wood axe
will. You can't use such an axe on hardwoods as it will break apart. For
example the Bruks hatchet I have now cannot handle the harder knots in
spruce, but will take Pine fine. So I go around and clear up all the pine.
Stack up the wood and switch to another axe to clear up the Black Spruce.
Usually doing such on different days.
Throwing might be a last gasp effort if everything else failed, but
certainly not the first-purpose design of a hawk.
If you eliminate hard contacts (from throwing or combat) you are working
with a very poorly designed tool. As it is around that which the whole
design is based. It would be like taking a wood craft hatchet and throwing
it and using it in combat. Now to be clear you can take a tomahawk and make
it so it will out cut a hatchet, just reduce the bit length to increase the
leverage you can apply and thin the profile out significantly. As well
change the steel to give higher edge strength, compression resistance and
wear resistance. However such a blade will chop poorly (wedge badly due to
hollow or flat grind) and would not be suitable for throwing or combat. It
would also still have an inferior head/handle attachement and handle.
Regarding CQB, historically, blade fighters NEVER banged their
weapons against another's weapon if they could help it.
Designing something to be able to withstand a given stress does not mean
that is the intended use of such a tool. For example you wear a lifejacket
when on the water so that if you fall overboard and get knocked out you
don't drown. This does not mean that the correct fishing technique is to get
someone to hit you on the head and throw you overboard.
Tomahawks were used in combat against similar tools and against other heavy
weapons. It is far from unlikely that contact could be made. Thus you had to
make the durability of the tomahawk much greater than an axe which would
never see such impacts. Every aspect which raises the durability, lowers the
tools function in other respects, edge life, edge compression resistance,
cutting ability. There are others issues as well such as the requirement of
ease of handle replacement which Andy discussed some time ago. That is not
an issue with an axe.
In regards to a straight handle, take a look at large knives. All quality knives will have well shaped
handles to fill out the handle and this is not a round shape. The curvature
of an axe handle is to increase comfort during use, raise the power of a
stroke and reduce the vibration from impacts. The knob is not just there to
keep your hand from slipping off, it is to reduce the compression force you
need and thus lower fatigue as well as raise your ability to torque against
it and thus increase the power of your chop.
There are other considerations as well. For example most traditonal
tomahawks have a profile in which the toe of the bit is in line with the
head of the handle. You do not want this for chopping. A norse profile
however has the same bit pattern as a felling axe. There are many things
which are inbetween a hatchet and an tomahawk and can't really be called
either one.
At a basic level, a tomahawk has many advantages over a hatchet, however
every advantage is always at the cost of performance in another area.
Tomahawks for example are generally made of softer lower alloy steels. This
means they are far tougher, more ductile and easier to work. It also means
they are far weaker, with a lower compression resistance and wear resistance
(and corrosion resistance but that difference is not usually significant).
Same with every other aspect of the design.
-Cliff
