- Feb 5, 2013
This is similar to the first thread I posted a week or two ago, but I ordered a 48" by 2" piece of .187" 1084 from Aldo and continued to read.
I've read the stickies and spent a lot of time searching and reading both here and the internet in general. I've looked at the many forge designs and the endless similar questions already asked. Maybe I'm dense, but I feel I'm on information overload and still not clear on what I need for simple heat treating, not forging, and because the plane blades I'm making only need to be heat treated on the sharpened end, not a long cutting edge like a knife.
I plan to make blades for the wooden hand planes I make, as well as random other woodworking tools I need. For the most part these are simple: a rectangular piece of steel with a simple bevel ground and honed on one end. They're 1/4 to 2 inches wide at the cutting edge, usually 4 inches long, some will be 6 to 10 inches long. All will need only the end with the edge heat treated. I hate to say it, but I need to do this as cheaply as I possible can. Normally I like to get the best tools or supplies I will need right off but in this case I need to start at the lowest cost. I'd love any advise in addition to any answers to my questions...
As I'm only looking to heat treat, not forge, can I get away with a BBQ, charcoal and a blower for hardening and kitchen oven for tempering? What is it called if not a forge, a heat treating oven? Kiln? Ruined BBQ? That seems the cheapest possible setup as I have all that already. I'm unclear on whether I'd need to add refractory material to the BBQ, in which case I might as well make a smaller, more efficient forge.
How important is normalizing in my case? Do you only do it when you've forged a piece, or will I need to do it with the cut and ground pieces of 1084 I'm going to use?
In any case, what is the most economical way of knowing the temperature? I can check the magnetism of the blade, but I'm quite colorblind and can't do it by color. Can I get by without a thermocouple since I don't have to soak the 1084, just reach critical temperature? As best I can tell I can't get a type K thermocouple probe and instrument for less than about $60, which eats up a LOT of the money for this project.
How do I check to see if the blade is no longer magnetic? This might be a silly question, but you pull the blade all the way out to check, otherwise the magnet itself can be demagnetized, right?
Here's stupid for you: I was playing around with some unknown high carbon steel before I found this site. I had trouble holding the small magnet I was using so I stuck it to the most convenient large piece of metal on hand. Luckily I realized what was going to happen before I actually tried checking the magnetism of the hot metal... I'd stuck the magnet on the free standing propane torch. Imagine: burning torch on bench, metal being tested stuck to it and pulled off, torch flying into lap...
Will a two brick forge handle a 2" wide blade? I'm concerned the blade will take up enough space that the flame doesn't circulate properly.
Why wrap brick forges with chicken wire? Is it a safety thing? Or is it just to keep if from falling apart?
Is there anywhere I can order a small amount of refractory cement, inswool, etc? So far I've only seen larger amounts (well, a lot more than I'd need for a tiny forge - remember, every penny counts in this case).
I had no idea there were so many types of torch burners for sale. I like the idea of making my own venturi burner - seems cheaper/I get to make it - but I can't figure out what design would be appropriate. Also, how do I plumb it to the MAPP or propane tank? If I go off the shelf, what burner would you suggest for this use?
Propane vs MAPP? I've read Mapp's additional heat is not necessary and can lead to hot spots, elsewhere I read "use mapp, it's hotter". I've got a normal small propane tank/torch setup with a few tanks.
I've read about using a deep fryer to temper since you can use a frying thermometer and control the temperature better than a home oven or toaster oven. Lacking a deep fryer, how about suspending the blade in a cooking try of oil so that the temperature is more stable and controllable? Worth it? A bad idea?
I have an ancient hand powered 5" wheel grinder. What grit wheel would you use? I want to replace the ancient black one that came with the grinder. I have a diamond wheel dresser coming. Can I use that with the old black wheel, or just newer types? I fear it would just shatter the diamond, this wheel is hard (to my totally naive eyes) and very porous. I was going to order one from McMaster Carr, can't afford the $40 blue norton 3X stones.
Thank you!
Thank you!
