So I tried the water first without the soap, not in anyway doubting you, just to try each technique and wow! I like the water method and with the dab of soap it may be my imagination but it seemed easier to clean-up stones. Just keeps getting better, extra fine stones just shipped so I'm exited to try them. Thank you again for all your valuable info you have shared!From memory, KME offers a curved convex diamond sharpening rod. With alot of use, sometimes base unscrews a bit, requiring us to turn it back tight. 1500 grit gets hazy edge, thought plenty sharp. Kid chasing mirror have several choices after 1500 KME diamond: Venev 1st gen bonded diamonds, CUT TO FIT DMT eXTRA EXTRA FINE-~3MICRON, Gritomatic 2500 SIC stone after appropriate SIC progression. Never used oil just watery sponge with drop a dawn dish soap or generic window cleaner.
I have tried all three techniques of oil/water/soap. I must say I am going forward with water/soap techniques, it works smoothly and easy clean-up. I got a hazy finish but for the low end knives I was learning own they were very happy to get an upgrade ...lol; I have some finer stones coming to take me up to the mirror finish. The base is fairly stable but I want more stability when working with higher end blades so I have made a template to lock base too but still allows me to swivel with ease. The key to KME Tool to me is remembering to let the stone do the work and not apply pressure downward on blade, just let it glide back and forth in the pattern you choose for both sides of blade and it will do all the work. There is a curved rod for the KME as Scott mentioned, I have it coming as well, KF-CVX $18.95.Great update! Really like how you detailed the step-by-step process instead of just posted something like: Received the kit, impressed, tried the stones, and now have a nice sharp edge. This is great info on the oil vs. water/soap too. Do you plan to try both or just stick with the oil? Were you able to achieve a semi-mirror edge with the 1500? How stable was the base supplied or using the handheld method?
I wonder if this kit would work putting convex grinds on knives and if it is simply a matter of switching angles progressively once you achieve the desired sharpness with the first angle.
I have a Wicked Edge pro pack 2 and I am very happy with it, very easy to use and I can get hair splitting edges with itSo I need input on which Sharpener should I invest in to always get the best edge every time.
My collection and trading consist of mainly Folding Pocket Knives, Small Fixed Blades and our on use of Kitchen Knives. Case, Benchmade, Spiderco, etc...
1) I have my eye on the Wicked Edge WE120 but is that the right choice for what I have?
2) What would you recommend and what makes you want what you have?
Thank you in advance; look forward to learning what's out there.....
Thanks for sharing your experience. This is helpfulI used to sharpen my knives on DMT diamond stones. I was pretty good at it and sharpened a lot of others' knives on my boat. Then I stopped for a long time and when I tried again, I was not any good. Probably just getting in my own head and need to to spend more time.
I got a Spyderco Sharpmaker first. Pretty good with it. Even brought back totally abused blades back to shaving sharp for a few friends. It is a good system.
I next purchased a Work Sharp guided system. I think it was the WSGSS. I don't remember because I didn't really like it and haven't used it in a long time. It's still in its box somewhere in another box somewhere in the garage or basement. It definitely has a learning curve and I didn't spend a lot of time learning with it, unfortunately.
I then purchased an Edge Pro Apex. I bought the full kit with the water stones and polish tapes and everything. I don't really like the stones and I never felt like it was very stable. The suction cup just didn't cut it and I never got proficient enough to achieve repeatable or consistent results. I still got a few knives sharpened satisfactorily and I do think it's a good design.
Most recently, I've purchased the KME Precision Knife Sharpening System. I have all of the diamond stones and a couple of the strops and CBN emulsions. I bought some various attachments: pen knife jaws, Hewlett JewelStik, and convexing guide rod.
I found the KME sharpener very easy to use after practicing on a few Chinese CRKT and Kershaws. Once I was comfortable with my results, I sharpened some much more expensive knives and have continued to be very pleased. I haven't tried a larger fixed or recurved blades yet but everything from the Keating Hornet to the XM-24 in size has sharpened up nicely. I expect to only get better with it.
From my experience, I would recommend the KME sharpening system. I did not find that it had a steep learning curve and I love the results. I look forward to sharpening some of my fixed blades and other knives.
Good luck!
