Peter Hartwig
- Feb 29, 2008
In case you have not noticed, we are not very impartial. Most here have made the decision they are worth it, spoken with our $'s and bought the knife or many CRK's
Like the last post says ... you need to handle one to really "get it". I resisted for years but all the while I was hoarding a lot of other knives in the $100-$200 range but was buying custom scales, clips, etc. Some of my mid-range knives had $300 sunk in them before I realized it. I finally decided rather than resisting any longer I'd sell a couple of lower end knives and buy a CRK to check out. I found a fair deal on a LNIB small Insingo and "got it" immediately.
I have since sold off a bunch more knives and have picked up a 25 silver edition and a tanto Umnum. I am very happy with the direction I've gone. I have been rotating EDC'ing the three since I got them and couldn't be happier. I love that I have three distinct knives here. They are all very different from one another.
I kept a few of my "lesser" folding knives that I still love and will still carry at times - Benchmade Grip from custom shop, Ritter Mini-Grip, ZT566BW, a couple of Zancudos, a few Case traditionals, and my old school original Spyderco Calypso Jr., SAKs, etc.
I never got it until I owned one. Worth it? Absolutely.
Are they "worth" $400? I don't know that any folding knife is really worth $400, and this is coming from a guy that has spent double that on folders before. However, if you have the disposable income and want a nice folder then a CRK is a good choice. CRK has exceptional fit and finish and a superb minimalist design. Do they cut any better than a $50 knife? Not really, but few people really need expensive sports cars either. If you are set on buying an expensive folder you can't really o wrong with CRK.
Lemme see if I can make a list........
Most of this stuff is for the sebenza 21, but a lot of it overlaps to the other knives as well
1. CRK is VERY innovative in the knife industry:
-First to ever use the RIL (framelock) on a folding knife
-First to widely use Ti handles
-Invented the double dip pocket clip that helps with in-pocket retention
-One of the first companies to start using the technique of stone washing blades
-The only reason s35vn exists today is because of CRK, and to some extent the same is true for s30v
-First to use the ceramic ball detent that makes the knife even smoother because it avoids any sticking problems that traditional steel detent balls have
-Pioneered the minimalist design that is extremely durable, easy to maintain, and can be taken apart and put back together a million times without any issues.
2. Tolerences are tighter than the aerospace industry
-CRK builds their knives with machines that they built specifically for making their knives, and have had to develop over many years
-The knives are built to such tight tolerences that everything is absolutely flawless in how it fits together
-The knives are much more durable and long lasting because of this. They will last a lifetime if you don't abuse them
3. They are perfectly designed folders
-The blade to handle ratios are amazing
-They have all the features you could need, and none that you don't
-Ti is sandblasted for grip
-Detent is great
-Great lock geometry, and a very strong lockup.
-Ergonomics are impressive considering how straight the profile of the handle is
-Thin in pocket, both in width and thickness, making carrying the knives much easier
-Lightweight for their size because of the Ti, the compactness, and the minimalist design that doesn't require heavy steel liners in addition to scales
-They are simplistic in their design, which adds to their durability. Not much to break, and super easy to clean
-The Ti framelocks have been refined over the years to be absolutely the best on the market
-CRK has been constantly fine tuning the few designs they already have rather than making subpar new ones every year, so they are able to really get things as perfect as possible
-The 21 has a true hollow grind that is actually slightly thinner a little ways back from the edge, providing years of sharpening life before the cutting performance is negatively affected by the blade thickening up. The 25 is similar but has a shallower hollow grind to add a bit more strength to the blade.
4. The fit and finish is impeccable
-You won't find a more aesthetically flawless production knife out there
-looks fall under personal opinion, but the fit and finish is unquestionably awesome on CRKs
5. Premium materials
-S35vn at the hardness CRK runs it at is not the ultimate in edge retention, but its perfectly fine for everyday uses and will last a good long while, especially if you strop it regularly
-The steel is easy to sharpen because it's run a little softer
-The steel is tough enough to keep the blade from snapping or chipping at the edge
-Ti is very light and strong
-Hardware is high quality so the screws won't strip out on you
6. The pivot bushing system
-Combined with CRKs legendary fit and finish, this system makes it so that the knife is rock solid with absolutely NO blade play
-Centering is typically perfect
-the action is glassy smooth
-after being broken in, the blade will usually fall freely even though the pivot is tightened all the way down
-The pivot has notches cut out of the inside for grease to go in. This allows for the knife to stay lubed for longer
-the tight tolerences give it a "hydraulic" feel when opening and closing. The action isn't the fastest, but its very satisfying to the discerning knife user
7. Warranty and customer service are excellent
-As long as you don't abuse the knife, CRK will always be willing to fix anything wrong.
-Very good company to deal with that truly cares about its customers
-small shop that has few employees and is closely monitored by Chris Reeve and his wife. They're right on the border of being midtechs
-many of the knives are personally inspected by Chris before they leave the shop
-excellent QC that very few companies compare to
-They offer a free spa treatment for all standard sebenzas that includes sharpening, re-sand blasting the handles, and tuning the knife back to perfection
-they will replace blades for a fraction of the price of the knife, or for free if it turns out that they failed because of a manufacturing defect
-The knives come with a tool to take them apart because CRK trusts its customers and knows that it's almost impossible to mess the knives up
-they also come with a small complimentary tube of CRK flourinated grease, which is arguably the best stuff to use with their knives
8. Exclusivity
-each knife has a birthdate and comes with a signed card
-not too many are made compared to many other companies
-the high price makes them less commonly found among the general population
-CRK has been making sebenzas for almost 30 years, so they are well respected in the knife industry
-CRKs are the culmination of decades of constant improvement
-CRK has won a rediculous number of awards over the years, usually dominating the competition every year. Keep in mind that this isn't because they're putting out the latest and greatest gimmicks and craziest new designs; it's because they've been consistently putting out the best quality production knives for many many years, and what they do, they do better than anyone else.
-Oh and you get to join the CRK club and look super cool compared to all your friends that don't have CRKs
Well, that's all I can think of right now......oh boy, I have far too much time on my hands
Please feel free to make suggestions for additions or offer corrections if you notice something is incorrect. This is just what I've gathered from my research over the past year when I was looking into getting my first sebenza.
AWESOME POST.....!!! :thumbup::thumbup:
I agree with nyefmaker. Krissig12 has created the definitive list. Well done!!
I love my Sebenza and will most likely never sell it. I appreciate every single thought and all the production that goes into making them. With that said I think they are overpriced by about $100. This is in no way a shot at CRK in any way, but just my honest opinion in their pricing.
I think that most people here would want their knives for $100.00 cheaper as I am sure that CRK would like to pay $50k less for each of the CNC machines that create these as well as about $7.00/hr cheaper for each competent employee..We could go on ad nauseum with tooling, taxes as well as environmental considerations/laws..Which, none of these are static..they change over time and not for the consumer.
Either way, I do get what you are saying. CRK is a small company..I seriously doubt they are rolling in the dough alot of people believe them to be..
BTW- pics..Post 'em up![]()
