Such awesome customer service has convinced me to order two kukris. If only I could decide on the type....
I'm not worried about it. It found you and one found me so it's all good.
Awesome brotha! HI and this forum are special places.
I ended up using epoxy to do the repair. I didn't have any Rit dye so I broke open a ball point pen and used the ink lol. Worked like a charm and even matched the color pretty well. I used a couple of small hand files to get the rings looking correct. I just have to stop at the hardware store on the way home for some black wet/dry sandpaper to bring by the luster. Its definitely not a professional job but it will make the AK functional. I couldn't use it the way it was, it was more than cosmetic. The horn would dig and cut the palm swell of my hand if I did any chopping. It is totally functional now and not that bad looking. It was a super deal even without the extra gift, now its even better. The 15 inch AK is really handy, more so than I though it would be. I will post pics after the final sanding tonight...Nice photo sharing, hairly horn crack is acceptable
That's a big crack. I usually use multiple coats of super glue to fill small cracks but that is too wide for that. I'd buy some 2 ton epoxy and some black rit dye. Mix the epoxy as directed and add one or two drops of the dye. Use a thin flexible tool to push epoxy into the crack.
If you use slow setting epoxy you can wait 10-15 minutes before to try to apply so it won't be as runny.
After 48 hours you can sand the epoxy to a flush fit, repeat until the crack is full.
Once crack is repaired you can polish the horn back to its original luster.
Please show me that I've already repair it now!I ended up using epoxy to do the repair. I didn't have any Rit dye so I broke open a ball point pen and used the ink lol. Worked like a charm and even matched the color pretty well. I used a couple of small hand files to get the rings looking correct. I just have to stop at the hardware store on the way home for some black wet/dry sandpaper to bring by the luster. Its definitely not a professional job but it will make the AK functional. I couldn't use it the way it was, it was more than cosmetic. The horn would dig and cut the palm swell of my hand if I did any chopping. It is totally functional now and not that bad looking. It was a super deal even without the extra gift, now its even better. The 15 inch AK is really handy, more so than I though it would be. I will post pics after the final sanding tonight...
Answer below...Please show me that I've already repair it now!
