Recommend a good belt sander?
Happy Face:
It ain't the gun, it's the gunner.
I have a 2X42 Craftsman. Why that one? Because the 20 year old 3X21 hand-held sander I had been using burnt out the bearings after the 6th blade I made on it and was half way through a blade when it happened. I knew I would probably die if I had to go back to using files but there was no way that I could afford even the cheapest 2X72 grinder.
Soooo... I first looked at a replacement for the hand held sander I killed. Then I looked at sanders such as you're looking at. In the end I chose the 2x42 because I felt that there are more belts available.
You've read the negatives, It's underpowered yet it runs too fast. Lets explore these charges a little bit.
Under powered: If I'm trying to hog a lot of steel off real quick by pushing it harder against the platen I can slow down or even stop the belt if I push hard enough. I'm probably just accommodating the needs of the grinder but this is usually not a big issue for me. I'm more concerned with getting the grinds and angles correct then to worry about how quick it removes metal. It's a whole heck of a lot faster than a file.
I suspect that If I had a nice 2X72 grinder I would have a hard time understanding how anyone could settle for anything less. I guess I don't miss what I never had.
It runs too fast: Yup. Sure does. But again I adjust how I do things because of it. An analogy - I've only ever hunted deer with a high power rifle and can't imagine why anyone would want to use a shotgun or muzzle loader. My brother-in-law prefers using a shotgun. To my way of thinking they don't have the range. In the case of the muzzle loader it has only one shot and reloading is not very fast. A deer could WALK out of range by the time a traditional muzzle loader is reloaded. It ain't the gun, it's the gunner.
If I could afford a 2X72 grinder there would be one sitting on my bench RIGHT NOW. Maybe some day I will but for now it's either the 2X42 (or some other similarly priced product), or hand files, or I don't make knives. That last option would sure save me a lot of money since I've never sold any of the knives I've made. Get whatever grinder you can as long as you can keep making knives.
LonePine
AKA Paul Meske, Wisconsin
It is REALLY nice to be able to slow a grinder down. If you work to build your own, try to go for varible speed or set up some pulleys at least.
p.s. lvegasguy, posting links to your ebay auctions is against the rules here. I doubt somehow, given it is your only post, that you are likely to ever come back though...
I notice you are from Montreal. You may find grizzly won't ship to Canada. You may also find that the Craftsman 2 x 42 is rarely available in Canada, and when it is you will likely find a Canadian price of over $250.00.
The advice you are getting here is correct. Most of the smaller ones discussed here will wear out belts so fast you will spend more on belts than you saved on the machine. They will remove stock in crude fashion, but so will a $30 side grinder.
I understand the good stuff is out of your range. You might want to look at the Coote grinder. Norm will ship to Canada. It is double your price range and has lots of shortcomings, but is a decent starter machine. You can order it without motor and just use an old furnace motor for the first little while and then easily switch motors when you sell a few blades.
Either way, welcome to the craft.
Rob!
Your knives look fantastic.
The Grizzly seems to be about the cheapest grinder that people recommend.
Well, I consider myself damn lucky then, because I found one within 10 minutes browsing online for 180$!
Here's an almost identical grinder to the OP with a few modifications. I've got around $150 in it overall. I've got a 3" slack belt, 8" slack belt, 12" flat platen and 8" contact all in one. Yes, I want a nicer grinder, but this one is cheap and great to learn on. It will make a great grinder at home for odd projects when I do get a nicer grinder.
OK, not the best overall picture but you can see that it has the 4" wide roller at the back of it.
I must congratulate you on your improvisation (is that a word??) skills! That is just downright cool.
