I think most of you are missing his "serrated blade" requirement.
I assume he wants a combo blade so the are only 3 choices that I see that have flipper and are not assisted.
JYD2 without the composite blade. I guess the smaller JYD would also work for you.
Ram
Storm both sizes are nice. The flipper is very small and hard for me to use.
Thanks for narrowing it down. It definitely is a requirement, I think I use the serrations more than half the time, so I definitely need at least one knife wit a serrated edge. However, if I can get two, I'm certainly open to suggestions of a non serrated one if it's really good as my second knife.
What's special about the composite edge?
Sorry to hi-jack the thread but I had the same problem with their speed-safe knives. I had the scallion and returned it 3 times to be repaired before I requested a comparable knife without the speed-safe option.
Huh, I thought the Scallion might be immune due to the design, guess not. Maybe it's just a little less susceptible.
I've had a Leek for about two years now and I would say without a doubt its been opened thousands of times and has never broken a torsion spring. It does seem a little weaker than when it was new but it has never broke.
I understand it's also something of a frequency over time thing. If you open and close it a lot quickly it's more likely to break. I find I'm using it quite often around people, so I pull it out, open, use, close, put away, pull out again as I realise I'm not finished, close, put away... repeat. That's probably something that puts some extra strain on it.
I just noticed Kershaw's site has RAM and R.A.M. As far as I can tell the R.A.M. is all black, while the RAM has a silver blade. Is that the difference, or is there anything else?
