- Jul 6, 2010
Rem 1100/1187, 12 ga (you can hand load 7/8oz shot if recoil is a problem) 26inch, vent rib, with screw in chokes... try light modified for trap, 5 stand,... remember that the cheek weld on the stock is your rear sight... try to find a MonteCarlo or trap stock that with some good advice from a competent club member you can "cut down" so your shot column agrees with your sight picture. I like to have the shot pattern a little high so I can track under the bird. If you plan on shooting 50+ birds per session it is important that under recoil the stock falls away from your cheek. Most all field grade guns have the butt of the stock low, so that under recoil the wrist area recoils into your cheek. This is not the way to enjoy clay bird sports. An 870 will work, but will offer a little more recoil.. regards Les
