recommend some wood to get started with handle making
HSC ///
just getting started as a side hobby, there are many sources for wood and various scales, I realize that.
I bought some micarta blanks form Tru Grit,
what should I get started with? what kind of wood? what represents the best value for a beginner?
They might even be thrown away in the beginning because they are unsatisfactory for sale or use.
Say I have $100 to get going for wood material or other blanks.
thank you
if you want something wood-ish that is easy to work with and fairly durable that you don't mind messing up i'd recommend diamondwood/laminated wood... it comes in various names. It is basically layers of wood and resin in a similar consturction to micarta or G-10 that polishes up easy and leaves a nice wood finish. It comes in many colors, it's easy to work and is not expensive so you don't have to break the bank.
I wrote this awhile ago, but it still holds true
Hey guys. Long time exotic wood carpenter here, and I have seen a lot of question about the best wood for making a handle the first time. Here is how I see it.
For the first time:
What we are looking for: What you want from a handle wood is a few things.
Firstly, it must be attractive. There are woods that are strong, oily and have great characteristics for handle woods, but are ugly or overly plain.
Second, it must be strong. wood's resistance to dents or dings is measured in janka rating. The number listed is the number of newtons required to force a 11.28 mill ball half way into a sample of wood. hardness is key so that the handle will remain in
shape after years of use.
Third, oily. This is often overlooked as many of the high end exotic woods used are oily, but the oils in woods have several benefits. Along with slowing cracking due to drying, the oils also keep the knife sanitary. Oils in woods like rosewood or ebony actively kill foreign microbes and pathogens helping keep the handle clean.
A last characteristic is heavy. Again often overlooked, the weight of exotic woods mean they can balance out a knife while still being sleek and thin.
Now lets get to wood choices. For a first few handles, we are going to be in the resonable price range "for exotics" as well as workability.
Bocote. It has a beautiful figure, really unmatched by any other woods. As the contours are formed, you get another dimension of of the banding. Strong and workable.
Rosewood family. Cocobolo, indian, honduran, bolivian rosewood as well as kingwood are great handle woods. Strong, pretty, oily as they come and smell lovely. Make sure you have a mask though as the dusts from these are very toxic.
Redheart. All around a great wood. It contains an amazing depth of color, combined with great workabilty and a nice figure.
Ziricote. Nice workabilty, a nice dark color combined with a very complex figure often called spider webbing. Its hard to find in wide pieces as the tree has very little heart wood with a lot of white sap wood. THe sap wood can be incorperated, but you
have to be careful so it does not overwhelm the work
Figured maple. Simply classic, its easy to work, not very heavy or hard, but certainly strong enough for average use blades.
Purpleheart. A rather common "exotic" wood, purple heart is a very strong and stiff wood well known for its bright purple hue. While the color can vanish right after sanding, it returns slowly, but will then begin to fade. Check the finishing section for tips to keep it bright.
Padauk. Similar to purple heart, Padauk is more workable, but it is also more toxic and its color a little more fleeting.
Woods to avoid the first time.
Ebony. Its a classic. Hard and able to take a great shine, but ebony cracks. Its so brittle its not even really a question of if it will crack, more when.
Ironwood. Dont get me wrong. Ironwood is probably the best handle wood in the world. But for a first timer in making handles, its hardness can make it to much.
Lignum vitae. See above. Often considered the hardest wood in the world, working it takes so much time and can be such a pain it is best kept till a later time.
Brazillian rosewood. While there is no working reason to avoid brazillian, the fact that it is illegal to harvest makes it a morally questionable wood. I have some that i pulled out of 90 year old furniture that was being scraped, but on the whole avoid this and the possible illegal activity that brought it to the states.
Burl woods. The heavily interlocked grain and twists mean that burl wood is hard to work evenly and has a tendency to not go where you want it to.
Snakewood. One of the prettiest woods around, its extremely high price, hardness and predisposition to cracking means it should be avoided for now.
"note that the above woods are still great for handles, but i would advise against using them your FIRST time for the issues i listed"
When picking a wood, there are a few things you may notice. first is that many exotic woods will have bands of sap wood. Often, they are very light colored parts of the wood and quite clearly marked. There are certainly woods with very gradual shifts to sapwood, but these are more rare. In general, sapwood is avoided because it lacks the color, figure and strength of the heartwood, but i can be incorporated into the design. Be careful though, as the great contrast of dark wood and white sapwood and draw the eye away from more graceful blade shapes.
Finishing: Different woods need different finishes. It depends on both the characteristics of the wood as well as its major shortcoming. Finishes are often aimed at overcoming the major short fall.
Color: Bright colored woods like purple heart, Padauk, redheart or blood wood have to major enemies. UV light and oxygen. To keep the color longer, full UV finishes are the best choice. Something like val-spar outdoor finish gives a full protective film to guard against air as well as uv protection to help keep the color.
Texture: Some coarse textured woods are beautiful and strong, but do not take a fine enough polish and make splinter in the hand. Woods like Jatoba and wenge fall into this group. Here, a thin coating of superglue/ cyanoacrylate provides protection from splinters for the user, as well as a thin coat that can be buffed to a high finish.
Oily: woods like rosewoods or verawood have an immense amount of oil found in them naturally, and rather than applying an entire finish, i find the best method to be simply buffing the handle so the heat draws oil to the surface, giving it a nice sheen.
General: My go to finish has always been tung oil. When in doubt as to the best finish, i find the fact that I can still feel the texture of the wood to be a great benefit.
As for where to find them, If you are in LA i could help, if not you could go on ebay, find bigmikeyc1, and tell him Ben sent you. He sells great stabilized woods and I have been using him for years. Burl source also stocks many of these woods, so he is another candidate. Search around and make sure to compare prices.
Two comments:
Hellspawn- Great post. Thank you.
I live on a wooded property and started by a making a couple of handles from maple I harvested and dried in the microwave (knowledge gained from wood working forums). Maple was easy to work and seems durable but is too plain for my taste. Then I pulled some walnut wood and from a stand by the creek. I got great contrast by using heartwood and sap wood. I love the look when sanded to 800+ and stained with danish oil. Next I'm going to try a gluing the darker maple to the walnut for a two-wood handle.
My point is that i'm starting out with free wood at least to the quality of the knives I'm able to produce today. Now, if this wood, or my use of it, proves not to be durable I may have another opinion.
Cheers,
Rosewood or more generally, the dalhbergia family which also includes African blackwood. If you are going to use an exotic, go with one of them. You will not be unhappy unless you are allergic to them. :thumbup:
I am a huge walnut fan. I think it is a great overall wood. It's hard but not too hard. Usually has great figure, but even straight grain stuff is classy looking to me. Our local Woodcraft usually has an overstock bin full of the stuff and some of it is very figured.
